Low Oil Pressure Indicator
Hi Guys,
I have been researching this problem in this forum. My problem is that just recently I noticed that the low oil pressure warning light would pop on intermittently. I started to observe the oil pressure gauge and noticed in the cold, at idle it would be just above 2 bar to just under 5 bar under higher rpm. When the car is warmed up, the light would come on when the gauge would dip to 1.5 bar at idle. The gauge never goes below 1 bar and has not exhibited the famous sudden drop to either 0 or up to 5.
Do you guys think this could still be the oil sending unit going bad or something else? No oil leaks anywhere and the car runs fine. Thanks for any input!
I also forgot: I added a quart of oil thinking that would solve the issue, but it still reads the same with no changes in the levels.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
COBB Tuning
Sep 9, 2015 09:13 PM
