Flash or not flash before going Track day...
Old Dec 15, 2011 | 09:09 PM
Ming's Avatar
Ming is infamous around these parts
Pls note that our pump gas, even the V-Power is no better than 91 in the US.
Old Dec 15, 2011 | 09:21 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Originally Posted by Aerodude
I don't think the flash will change the car so much that you have to "get use to it" before driving on the track. As others have posted, you certainly don't need the flash before going to the track -- but if you're going to flash it anyway, I don't see any reason to worry about doing right before your track event. The flash will give you a bit more power, and the throttle mapping will change, but it doesn't completely change the driving characteristics of your car. Besides, you probably shouldn't be out on the edge that much anyhow .
80hp rise as per Softronic mention is not a bit more power to me :P But as per you advise, I guess it may not a needed to "get used" to it. Thanks
Old Dec 15, 2011 | 09:23 PM
boyg's Avatar
@@ Are u sure? As per I know, our pump gas are 98 Octane besides Sinopec, they are probably 96 or 97. As my M3 requires 98 Octane in the user manual, it ran fine on Shell but not Sinopec(power down significant noticed)
Old Dec 16, 2011 | 12:12 AM
Ming's Avatar
Our rating is different from the US. There is an instrument that can read the octane level.
I had serious timing being retarded running with V Power. Then I added small amount of 104, things improved a lot.
You may need to discuss this with your tuner, as they may need to change the settings.
Also, fuel at Mainland may be even worse.
Old Dec 16, 2011 | 07:50 AM
biobanker's Avatar
biobanker is infamous around these parts
Regardless of whether or not you flash it or not, keep the car below 5/10ths.
You should be going NO WHERE NEAR the intensity where 400hp and 500hp are different.
If more experienced drivers in Miatas are not passing you, you're going too hard.
Ive seen too many nice cars in the wall on the first track day.
Old Dec 16, 2011 | 09:43 AM
johnspeed's Avatar
....more power= more fun....
Old Dec 17, 2011 | 08:17 AM
StPatsDay's Avatar
StPatsDay is infamous around these partsStPatsDay is infamous around these parts
It's like if you have a hot girlfriend and she's like, "Skirt, or pants suit?"
Old Jan 5, 2012 | 10:36 PM
boyg's Avatar
I have it flashed finally, tested it in rain last night and it didnt hold 1bar boost as I expected, I have seen 1.2 bar maybe half a second and then went back to 0.7 0.8...
Old Jan 5, 2012 | 10:49 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
What flash did you end up going with? I also get about 1.2 bar -- but I haven't tried to hold it long enough (since I'll end up going too fast ). You can try to be in a higher gear when you're testing. In the lower gears, you might get towards red line too fast to see what it will hold.
Old Jan 5, 2012 | 10:55 PM
boyg's Avatar
Im on Softronic now, I thought I should see 1 bar holding at least, what bar you could hold on yours? And I am thinking about the wastegate since I have the 710n DVs upgraded.
Old Jan 5, 2012 | 11:43 PM
Ming's Avatar
I have a set of used 1 bar wastegate. Any interest?
Old Jan 6, 2012 | 12:30 AM
boyg's Avatar
Yes Im interested, contact has PM to you.
Old Jan 6, 2012 | 07:25 AM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
i would get your suspension sorted first.
maybe try 996 gt2 spec if u can, to start
Old Jan 6, 2012 | 11:17 AM
boyg's Avatar
Agreed, and I have them sorted out with a nice setting now, all 4 corners are running about 2.5 degree camber.
Old Jan 6, 2012 | 11:42 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
ahhh go for it and turn off the PSM button as well....
