Where does the car read the boost level? from more than one place?
Old Dec 15, 2011 | 04:02 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I've been trying to educate myself on how our cars measure the boost level, and I can't figure this one out: I know that a boost leak can cause the ecu to request higher than normal boost levels so that the cylinders will receive the expected/requested PSI, and we can see this higher requested level on the in-dash boost gauge. If this is so, then does the ecu read the boost level at two different places? One location which shows up on the in-dash reading (closer to the turbos?) which would read the higher than usual boost level, and a second location (after the leak?) which would tell the ecu that the delivered PSI was less than that requested?
I know that the answer to my question is probably a simple one. Please help educate me!
Old Dec 15, 2011 | 07:24 PM
MBailey's Avatar
The only place I know of to read boost on the stock configuration is the sensor in the middle of the Y-pipe.
Old Dec 16, 2011 | 02:55 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
correct and this oem sensor can only read max 2,5bar
PorscheEnthusiast
Nov 13, 2015 02:23 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Aug 21, 2015 06:34 AM
Aug 20, 2015 12:17 PM
