tire size help
tire size help
size of wheels are
front: 19x8.5
rear: 19x11.5
is it ok to use the following Pirelli Pzero tires
front 235/35-19 (total diameter 25.4")
OR
front 245/35-19 (total diameter 26")
rear 305/30-19 (total diameter 26.3")
i've done some research but have found some conflicting information.
has anyone run these tires without problems ?.. just don't want premature failure of the differential.
front: 19x8.5
rear: 19x11.5
OR
I just added Hankook evo's at 295 30 19 and 245 35 19. That's as close as I could find with the same tire brands, but the fronts only fit within a millimeter or two.
Read through these posts for all the info:
https://www.6speedonline.com/forums/...o-rubbing.html
Look at the 'revs per mile'..more directly applicable to 'differential abuse'..
the 245 is 800 revs per mile..the 305 is about 790-795 (i am guessing here...tirerack does not have it listed).
A difference of about 10 revs is about ~ 1% (10/800=1/80=1.25%)
COBB Tuning
Nov 9, 2015 08:02 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
