Secondary fuel pump
Thanks but i already bought the 044 pump and was told it was straight forward to put it in place of the fuel filter, car is already in workshop with engine out and i told mechanic i would try to grt some pictures or instructions. The guy i bought the pump off said he would jot down instructions and send with pump but he must have forgot.
The other place you can go is underneath the car to the left side cross brace and mount it on top of that and run your lines back up to the afore-mentioned fitting. Someone makes a weather resistant cover for that pump but I don't know the supplier. I've done it both ways and either seems to work just fine. Only thing with an inline pump setup like this is I think you need an inline pressure sensor (there's a barrel fiting made with 1/8 NPT female for the sensor. You can then set up an alert (big red Moroso light, or something) to let you know if the pressure ever drops off. Reason for this is that if your primary Porsche in-tank pump fails, the car will just stop. If your 044 fails and your program is relying on that extra fuel, the engine might go lean at high RPM and you would never know it. I never had that experience but is suspect it is a probability that you would lean out.
adnanm3
Nov 22, 2023 02:43 AM
