The pressure testing joy just never ends ...
Old Feb 5, 2012 | 07:50 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
My latest problem ....
Can I unscrew these the barbed connectors, and then re-install with teflon tape or something similar ? The one circled is definitely leaking at about 6-7 PSI, others seem fine.
Old Feb 5, 2012 | 08:15 PM
Why not? Of course..
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 5, 2012 | 08:19 PM
JSBear's Avatar
I figured, but I wanted to make sure. I'm an IT
guy who enjoys working on his car. I like to be sure, as there are others on this forum with more experience than I.
Thanks.
Old Feb 6, 2012 | 09:40 AM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
Yes you can remove and seal with either teflon tape or even better yet use Loctite PST 567. It better protects against dissimular metal reactions, seizing, galling etc.
Don't just do the one that is leaking do everyone you can. Do it once, do it right.
Old Feb 6, 2012 | 10:35 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Have you put a check valve somewhere in that line you have circled? I believe the original venturi tube has a valve just before that line as it leaves the TB. There should be no leaks downstream from the check valve, or at that fitting, for that matter.
Old Feb 6, 2012 | 11:12 AM
JSBear's Avatar
Believe me I'm all over that, already replaced the venturi
due to bad check valve, as well as replaced the check valve that connects to the brass barb next to the circled item.
Jul 29, 2019 11:13 AM
Apex Chase
Mar 28, 2016 02:00 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
The Oss
Aug 24, 2015 08:19 PM
Gewgaw
Aug 19, 2015 11:52 PM
