Plenum Leaks - Lower Engine
Old Feb 21, 2012 | 04:41 PM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
I did a leak test and detected a leak in plenum hoses. I can see the leak but I can her the air coming out.
I need to lower the engine to repair the leak. What is the best way to do it?
I only need to remove the nuts from the motor mounts or is necessary to disconect more parts?
Old Feb 22, 2012 | 09:19 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
You should be able to lower the engine a good four inches. Disconnect and remove the air cleaner. Also disconnect the boost hoses from the y pipe. Support the engine and remove the engine mount bolts. Carefully lower keeping an eye on everything.
Good luck !!
Old Feb 22, 2012 | 02:03 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Lower it enough to let it rest on the x bracing. Take a very thin single ply piece of toilet paper and clip it with a hemostat and start moving it around in front of the engine and to the left of the oil tank. When you find the leak the paper will really begin to flutter. If your hands and arms aren't too big, you should be able to reach the hose clamp that adjoins the plastic pipe to the aluminum plenum. If you're lucky, the clamp will be in such a position that you'll be able to get a 1/4 drive socket on it and tighten. 7mm, I think.
Old Feb 22, 2012 | 07:28 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
You will put substantial stresses on the left and right engine to body coolant hoses lowering the motor to the bracing (~4 inches). This is the reason the shop manual states 1.5" drop max. Remove the airbox, IC hoses and these 2 coolant hoses to be safe.
Jul 29, 2019 11:13 AM
salesguy01
Mar 25, 2019 09:39 AM
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
The Oss
Aug 24, 2015 08:19 PM
magoochi
Aug 23, 2015 05:54 PM
