DIY Polished 3rd brake light
Old Mar 15, 2012 | 10:50 PM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
Just wanted to share a simple mod I did last weekend. My third brake light was looking tired. If you look closely you can see that from the factory there are raised lettering, part numbers, and various markings on it. I decided to sand them away and then polish the plastic. It only took me about 20min and I am pretty happy with the result. Below are pictures of the before and after. Sorry for the poor cell phone quality.
Here is what I did:
-Taped off the area around the light
-Sanded off letters with 220 grit
-Wet sand with 800 grit
-Used off the shelf 3 step plastic polishing kit to finish it off
Note that I take no responsibility if you try this and are unhappy with the result. It is possible that you could crack or damage your 3rd brake light, so be careful.
Old Mar 16, 2012 | 05:37 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
nice work
a smoked or clear light looks really good with a black car imo
Old Mar 16, 2012 | 10:10 AM
wross996TT's Avatar
why didn't you just remove the light and perform said polishing?
Old Mar 16, 2012 | 02:01 PM
unterbergamotte's Avatar
unterbergamotte has a spectacular aura aboutunterbergamotte has a spectacular aura about
Brk lmp
MINE LOOKS DIFFERENT. MAYBE I BUFFED TO MUCH...
Old Mar 16, 2012 | 02:53 PM
you still have the raised numbering and markings though :P
I thought about taking it off to do it, but I believe the tape was easier and I didn't have to worry about it moving around while sanding.
Old Mar 17, 2012 | 08:19 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
If I can remember, someone in this board had mentioned how hard it was to reseat the gasket back in after removing the third brake light.
Lowtush
Jan 25, 2022 10:48 AM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
cerbomark
Aug 26, 2015 10:10 AM
The Oss
Aug 24, 2015 08:19 PM
