What is your ride height front / rear
Old Feb 5, 2013 | 06:34 PM
  #31
SUB-ZERO's Avatar
SUB-ZERO has a spectacular aura aboutSUB-ZERO has a spectacular aura about
Originally Posted by MBH
Can anybody out there with H&R (or any other lowering springs) measure their fender height to compare to my measurements (25.25" front, 24.75" rear)
I'm wondering if maybe I'm missing a rear spring perch or something
Shouldn't the front be lower than the rear?
Old Feb 6, 2013 | 05:58 AM
  #32
MBH's Avatar
MBH
MBH has a spectacular aura aboutMBH has a spectacular aura about
that's why I'm asking lol, even though the factory suspension cars I've seen were all a bit lower in the rear (didn't measure, just looked that way). Although, technically speaking, it's just the fender height, not the frame height etc, so the car might actually be level, with just the fender itself being lower since the rear wheels don't need to turn.
I used to have a VW CC, came lower in the rear than the front by a good margin. Bought coilovers & fixed that, but it was just the fenders that were different heights in the sheetmetal
stock vs coilovers.
Old Feb 6, 2013 | 04:49 PM
  #33
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
stock vs coilovers.
That's because the wheel well height in the front is higher than the rear, remember the wheels turn out and the car bounces so it needs more clearance. Also think snow covered wheels for cold places...
The car behind with the coil overs and the wheel well height exactly the same is actually sitting forward quite a bit, you can even see it in the picture that the car is not level. Measure the rocker to the ground on the coilover car, the rear is likely 1" higher or so.
Old Feb 7, 2013 | 07:04 AM
  #34
MBH's Avatar
MBH
Right, I understand that - that's what I was getting at exactly, just using my old car to show a more extreme example. I lowered the front much more than I did the rear
Stock fender height is lower in the rear on a stock 996 turbo, correct? (see post #15). So, basically to keep the car factory 'level' (without regard to corner balancing) the fenders should be slightly lower in the rear
Old Feb 7, 2013 | 07:41 AM
  #35
#9shooter's Avatar
#9shooter has a spectacular aura about#9shooter has a spectacular aura about#9shooter has a spectacular aura about
M2fit4u2. Just get a pair of springs. H&r or Porsche sport springs. They lower around a 1". That should even you out
Old Feb 7, 2013 | 02:25 PM
  #36
nitrosobmw's Avatar
nitrosobmw is infamous around these parts
I just took some better measurements and the front is actually higher than the rear, I have H&R springs with oem shocks, final #s are 25 5/16" F and 25 3/16" rear, a difference of 2/16s total.
Old Feb 7, 2013 | 05:03 PM
  #37
King James's Avatar
My suspension is stock and I'm 26" all around... Looks more like .75 on those H&Rs...
Old Feb 8, 2013 | 07:28 AM
  #38
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
I just went back and checked mine again as I had the suspension further track set and I'm at about 24.75" front and back.
Old Feb 9, 2013 | 10:12 PM
  #39
ard's Avatar
ard
I'm at 26" front and rear, on 315/30-18 and 265/35-18. Corner balanced, on the upper range of GT2 ride heights.
(BTW, Porsche specs ride height from the floor to specific chassis points, not fender arches.)
Old Feb 10, 2013 | 09:29 AM
  #40
MBH's Avatar
MBH
your car looks so mean with the advans on it
any trouble being that low on the track? do you have spacers on it? Perfect stance... now if only it were easy to drive it that low lol
Old Feb 10, 2013 | 11:28 AM
  #41
Etchhead's Avatar
No rubbing issues at this height and it tracks fantastically. Looking forward to March30th event at Laguna with their 105db restriction and my new alignment and brakes.
When I use the turbo twists I have something like 8mm and 16mm front/back. With the GT2 wheels I just use the ~8mm in back. Fills up the wells nicely.
Old Feb 12, 2013 | 09:35 AM
  #42
MikeG's Avatar
MikeG is infamous around these parts
I put in H&R springs last week and I'm sitting at 25" front and 24.75" in the rear.
I love the way the car rides and handles so far.
Old Feb 12, 2013 | 10:36 AM
  #43
MBH's Avatar
MBH
Thanks for posting - that 'confirms' that my numbers weren't out of line.
did you buy the springs new or used?
Old Feb 12, 2013 | 11:20 AM
  #44
MikeG's Avatar
They were barely preloved.
Old May 12, 2013 | 04:33 PM
  #45
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
Ok, everyone with the rears set at 24.75", how much travel do you have before you are hitting the bump stops?
I rolled my fenders without the shock hooked up until the tire cleared the fender lip. I installed the shock/rim/tires and lowered it until it bottomed out.(block of wood under tire and lowered car to the ground until it was stuffed into the wheel well)
I was on the bump stops in roughly 1/2"!!! The car does feel like it bounces will driving. I have a JIC suspension on the car. How low it too low and does anyone else have this issue?
My ride heights(to center of arch to the ground is,
Front- 25"driverside, 25 1/8"passsenger side
Rear - 24 13/16" driver side, 24 3/4" passenger side
