Fuel gauge issue after new sender install
Old May 19, 2012 | 03:56 PM
Speedtrapped's Avatar
Speedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant future
I have searched, and a couple of threads described when sender is replaced, as long as the battery was disconnected, the reset is easy, fill car up and pull battery for 10 minutes. I tried this, and I'm always full, so the sender isn't reading correctly to the dashboard. Am I stuck? Do I have to take car to dealership and have the procedure done, where they empty tank to reset? Should I try and fill her and reset again?
Any ideas.
TIA
Stephen
Old May 20, 2012 | 07:38 AM
Tim941NYC's Avatar
Stephen, check two things. If I remember right there is a little arrow on the whole unit that points to a notch on tank. then tighten the ring. two make sure the mess of hoses in the tank are clear of the float. good luck
Old May 20, 2012 | 04:20 PM
Tyvm for that, going to check this week....
Old Jun 26, 2012 | 07:24 PM
Update....bingo sender float was caught. Reseated and I had about 6 drops of gas in tank. Happy now I can know what fuel is in tank.
Ty
pwdrhound
Sep 16, 2021 02:27 PM
Oct 6, 2015 05:20 AM
SharkyShark20
Sep 19, 2015 09:54 PM
tkebp1275
Aug 31, 2015 06:35 PM
barncobob
Aug 19, 2015 02:35 PM
