x73 or 997.1 motor mounts
Old Jun 20, 2012 | 07:54 PM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
I want to upgrade the transmission and motor mounts, I have searched the forum regarding the motor mounts, and i have narrowed down to 2, 997.1 MM or x73 MM, can anybody give a comparison between the two, is the 997.1 MM and upgrade? or would a x73 be better as i could not find any comparison. I know the 997 ones are liquid filled, not sure about the x73.
I planning on going with the 997 transmision mount.
thanks
Old Jun 20, 2012 | 08:09 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Im doing a 997 trans mount w window weld mod on Sat. Id be interested in hearing about "better" (non solid) motor mounts as well.
Old Jun 21, 2012 | 12:15 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
If you want to stick with factory parts, Suncoast sells a 964RS engine mount kit that is solid rubber with no liquid filling. Anything will liquid inside is going to fail before anything that is a more solid material. The 997 tranny mount is also has more rubber in the inserts. If you're willing to go after market, Torque Solutions has a semi solid motor mounts (that claim not to cause sonic vibrations that set off the engine knock sensors) and a factory tranny mount that filled has polyurethane inserts instead of rubber.
Old Jun 21, 2012 | 08:25 AM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
torque solutions.
BenTT
Jul 22, 2021 02:38 PM
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
