Durametric...ABS Brake flush
Old Jul 15, 2012 | 07:26 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Question, has anyone actually cycled the psm/abs using durametric v6 yet? And if you have what is the proper sequence of valve activation? Thanks.
Old Jul 15, 2012 | 08:54 AM
jpflip's Avatar
I've tried with the beta version of software 6 and it did not work. Having access to a PST2 I did it with the repair manual step by step and it work like a charm and it is really easy to do. I hope you got the repair manual. The procedure is at page 829-830-831.
Note; With the pump activated you will see that you only bleed the front right brake and also the pump is activated for a short period of time so you may have to select the pump more than once....
Old May 28, 2019 | 05:46 PM
Cory Smith's Avatar
Cory Smith is infamous around these parts
Which repair manual are you referring to? I'm also trying to do this but I'm having problems finding info on it.
Old May 29, 2019 | 06:31 AM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
pm me your email, i'll send you a copy. It doesn't say which to activate using durametric however...
jaehoppa
Oct 22, 2015 09:17 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
