Lightest 18" wheels
Old Oct 24, 2003 | 06:55 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Lightest 18" wheels
What are the lightest 18" wheels that will fit the TT? What are the exact weights? Will they also handle the brembo 8 piston set-up?
Old Oct 24, 2003 | 08:56 AM
john stephanus's Avatar
john stephanus is infamous around these parts
Fikse Profil 10's are very light and do fit the 8 piston Brembo kit.
Old Oct 24, 2003 | 08:57 AM
20C4S's Avatar
Fikse & Kinesis maybe
Old Oct 24, 2003 | 09:22 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
As a point of ref.....my file says the rear 10J Carrera Design is 23.36 lbs and the rear 11J Turbo hollow is 24.6...........IMO those are both very good weights for 10 & 11J 18" rims.
Old Oct 24, 2003 | 09:28 AM
Guys, I'm an engineer ... numbers please!
Old Oct 24, 2003 | 10:05 AM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
Profil 13's in GT2 specs (8.5" and 12" wide) weigh in at approximately 21.5 and 22.8 lbs front and rear, respectively. You will need to be very precise in doing measurements so that Fikse can make front 18" wheels that will clear the Brembo Le Mans setup. It's my understanding that it can be done. Given your engineering background, I'm sure being exact won't be a problem.
Old Oct 24, 2003 | 08:57 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
I would suggest contacting FIKSE and getting some specs from them.
Bader996
Aug 27, 2015 10:01 AM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
ModBargains
Aug 20, 2015 12:28 PM
