Clutch bleeding
Clutch bleeding
Hey all, I replaced the slave cylinder in my car a few months ago. For some reason my clutch has never felt the same. When it comes back up it's like there are a two notches. It usually almost always comes back up all the way it's just those two notches. And every once and a while when it's cold it doesn't come the last 10th of the way up, but if i touch it with my foot again it pops up that last little bit. It seems like there is air in it. I bought a motive, and bled it again and it doesn't look like there are any bubbles coming out. Any suggestions? Should I bleed it more?
I had the problem of the pedal not coming back up completely and I had to bleed about three times to fix it. Strange because I did not see any air coming out on the last bleeding but it fix my problem...Between bleeding I depress the pedal several times and force it up when it refuse to come back up completely to try to get as much fluid to move as possible and may be get the air out completely of the slave. I did all this with the tank pressurized over 10 pounds...
I got an extra quart of fluid last night. Ill put her back on the lift tonight and see if I can get it fixed! I was all worried because I pumped the bleeder past 10lbs last time. Glad I'm not the only one!
Hi I just changed my slave and bled the clutch fluid. Everything feels great except I feel a slight click in the clutch pedal about 1" from the top when releasing the clutch pedal in whatever gear. Basically like a notch as you described in your post. The clutch always comes up to the very top, I just have that "click" feeling in the pedal right before the very top. Did bleeding your system again help your issue?
Thanks,
J
Thanks,
J
997TT - notchy clutch pedal
Hi
Bringing up an old thread.
I am having the same problem on my 997 Turbo after a slave cylinder change.
Notchy feeling at the top end, have pressure bled the system a few times. Installed a new steering pump and reservoir.
Clutch feel is great with no gear change issues.
Did anyone sort this please?...
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
