street suspension upgrade 996TT recomendation
Hi,
I have 996tt with X50 and PSS9 with GT2 geometry as well as height , what could I change in my suspension to run mostly street but I dont like to loose too much comfort....
Are you still AWD or are you RWD? I've heard that steering feel improves dramatically and becomes more precise when you go RWD. That might be something to consider if not done already, and if you can tolerate being RWD only of course (don't forget you'll need to add a good aftermarket LSD).
Tomy, I suggest you add eibach adjustable sway bars, tarret drop links and strut braces from eagle day. Once fitted have your shop align your wheels and suspension to a stage 2 track set up. I promise you will be very happy with the outcome you do chew ur front tyres but for turn in as fast as a boxster who cares. If u wanted even more I suggest upgrading ur engine and gear box mounts.
Good luck.
Good luck.
04-28-2022 12:38 AM
ECS Tuning - VW
08-20-2015 02:01 PM
ECS Tuning - VW
08-19-2015 02:36 PM
ECS Tuning - VW
08-19-2015 01:23 PM
