Boost leak test
Old Oct 29, 2013 | 10:21 AM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Boost Leak Test
I have done it both ways.
But to answer your question, by plugging the output side of one turbo and charging the output side of the other, you are creating boost pressure in the intake side of your car's system -- basically balancing boost across the two sides via the intake Y-pipe. The same way the turbos do, but just on one side as it's easier that than adding pressure on both the driver and passenger turbos' output sides.
It has nothing to do with the exhaust as the exhaust simply spins the turbo fans to create boost, which you are replacing with pressurized are in a sealed off intake system.
Old Oct 29, 2013 | 06:32 PM
supergoji's Avatar
supergoji is infamous around these parts
wont 20psi blow out the oil seals???
Old Oct 30, 2013 | 08:42 AM
bmwtmx's Avatar
bmwtmx has a spectacular aura aboutbmwtmx has a spectacular aura about
I have a quick question. If you had a boost leak that was significant, wouldn't that throw a CEL? I mean, these machines are fairly complex and I would think that the brain could easily detect a boost leak....
Old Oct 30, 2013 | 01:39 PM
ttboost's Avatar
Yes, usually if a boost leak is so bad it checks a light (CEL), you can also hear it...
Texas1
Sep 20, 2015 09:12 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
sparks
Sep 8, 2015 03:03 PM
MrJoshua
Sep 6, 2015 02:06 PM
Sep 3, 2015 04:56 PM
