How to change rear camber on stock suspension
Old Mar 26, 2013 | 05:14 AM
adelino's Avatar
adelino is infamous around these parts
Hello,
I have a stock suspension on my 996 tt. The tires are showing cords on the inside, and are ok in the outside.
Is it possible to put less camber on the rear for my next set of tires?
How can i do that? Is it simple like a DIY ?
Thanks,
Adelino
Old Mar 26, 2013 | 07:53 AM
The Pork Hunt's Avatar
The Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond repute
Usually too much toe in or out is what wears the corners, I would just take it to a shop for an alignment and have them get the toe as close to neutral within the specs as possible, as long as camber is close to factory spec you should be fine. Here is a DIY link as requested, just search....
https://www.6speedonline.com/forums/...lets-chat.html
Old Mar 26, 2013 | 08:35 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
Sounds like too much negative camber to me. If your car is lowered, you may be unable to get the rears in spec, and will have to buy some adjustable control arms to compensate. That's what I had to do with lowering springs.
COBB Tuning
Jan 1, 2025 09:02 AM
Mackchacha
Jul 9, 2019 11:03 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
