New turbos just showed up
Old Mar 28, 2013 | 12:43 PM
johnspeed's Avatar
Actually the inner Milltek piping is 2.75.
I cut the 2.5 muffler tail pipe section off and had a 2.75 section welded on instead..
Did a thread on that a few weeks back.
Old Mar 28, 2013 | 01:24 PM
FlyingGuy's Avatar
FlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant future
I was reading up on what you had done. We saw that the inner pipes seemed a bit larger, but still not 3 inch. So instead of cutting and rewelding like you had done, I think we are going to go true 3 inch.
how did you determine that the inner piping is actually 2.75? how were you able to measure the inside?
Old Mar 28, 2013 | 01:55 PM
johnspeed's Avatar
When I bought it new and installed it, you could see the inner piping thru the connection pipe that joins the muffler that they were a lager O D then the 2.5 tail pipe. Plus I was told I was right by Milltek UK.
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
