996 IMS failure rates? Other things to look out for?
Old Apr 17, 2013 | 02:16 PM
docboy's Avatar
docboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond repute
^Great post Steve. Thanks.
Old Apr 17, 2013 | 02:18 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Originally Posted by docboy
Does anyone have a list of the required maintenance at xxxx mileage intervals? It would be nice if I could price out some of the required maintenance items.
My initial thoughts are that 996 seems to have a lot of "small issues." But in comparison my 2010 Acura TL SH-AWD 6MT has the following issues (a lot considering it's a Japanese make):
1) 3rd gear pop out, which the dealership finally replaced the 3rd gear set after numerous complains I made and also did a new clutch assembly (no charge warranty)
2) unresolved "diesel" engine noise when car is warm
3) Now that my clutch assembly is new, the clutch doesn't sound right
4) rear headrests that needed replacements (warranty)
5) Many owners are reporting propeller shaft issues/replacement
The issues don't really get any worse at 600hp on a 996TT. As a matter of fact it actually gets more reliable since issues like diverter valves have already been resolve at that power level.
You can't even imagine the reliability issues with 600hp Japanese cars (The Supra and GT-R excluded).
Good luck,
Steve
Old Apr 17, 2013 | 03:17 PM
docboy's Avatar
Good luck,
Steve
Steve,
I'm curious, how does the maintenance of your 996 compare to your M3 and M5?
Old Apr 18, 2013 | 06:02 AM
Both the M3 and M5 have less of the small problem areas, but they have some high dollar problem areas that easily offset this.
The SMG pump on the M5 cost several thousand dollars if it goes and the VANOS hub on the M3 can fail and take the whole engine out. So, all cars have their problem areas. With that said I have 55,000 trouble free miles on my M5 and 160,000 miles on my M3 with no major issues. I actually do HPDE's in my M3 and I have owned it since it had 11,000 miles, so it's been a great car. I'm sure I'll have it until it dies, or I put an M5 V10 in it.
Don't be afraid of the 911, just get a good one and maintain it.
Later, Steve
Old Apr 18, 2013 | 05:26 PM
svt_Troy's Avatar
svt_Troy is infamous around these parts
Awesome thread! I've pretty much been searching through past threads for this very info. Thanks a lot fellas and keep them coming. I'd love to see cost of some of these repairs as well though
Old Apr 19, 2013 | 11:48 PM
docboy's Avatar
Continuing this thread... how about the issue of RMS (Rear Main Seals)? Does the RMS issue affect the 996tt, or all 996 models? One site mentioned that the RMS issue was resolved in MY2003+. True?
Old Apr 20, 2013 | 08:01 AM
'02996ttx50's Avatar
my '03 currently has an rms leak. slow, but very real. it pisses me off greatly.
Old Apr 20, 2013 | 09:33 AM
djantlive's Avatar
Usually rms is associated with cars not driven often. It is rare on tt engines.
Old Apr 20, 2013 | 09:36 AM
that wouldn't be me. 102 k miles
Old Apr 20, 2013 | 02:05 PM
docboy's Avatar
Is yours a tt? I assume it is, given your login name....
Old Apr 20, 2013 | 02:31 PM
it is. ..and my 1st one never leaked, gotta fix that.
Old Apr 20, 2013 | 02:45 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
- damaged front diff if previous owner didnt use right size tires
So I have read a lot of threads about this, but is there proof this even happens? I realize lots of people have thoroughly explained how the AWD system works and have very solid theories how mismatched tires would cause issues, but have these theories on failure ever been linked directly to a failure? I struggle to find any proof.
Viscous diffs in general suck *****, spend some time at a drag strip and that becomes readily apparent. Also plausible, failures here we think are related to mismatched tires could also simply be due to a standard number of failures that will happen regardless. I wonder how many of our front diffs are failed and we don't even know? I'll bet a lot.
There is also the mythical 3% difference variation nobody can confirm or even know where it comes from. To compound the issue further even with perfectly matched tires there are things like thread depth and tire pressure differences which will throw the best matched tires out by more than 3%... Rears wear out twice as fast (or more) than fronts so bald rears and new fronts will be hugely different. There are LOTS of guys who run mismatched tires (look at your next event) and they don't report any problems at all.
IMO, this is plausible but unconfirmed.
Old Apr 20, 2013 | 04:08 PM
i'm not trying to be argumentative, ( or following you as i posted on this topic in reply to you a moment ago, in another thread/time/place ) but it does come from porsche literature. i have read it. now i don't have it handy, so if you again, want "proof" i can't oblige just now. but if i am correct, i am sure it can be found, i just don't feel like searching. but i am sure i have read it, and that i am not fabricating it, or adding to a *myth*. the 3% acceptable range between tire size/differential front/rear for the 996 porsche turbo is factory recommended.
salesguy01
Mar 25, 2019 09:39 AM
Oct 6, 2015 05:20 AM
pshep138
Sep 1, 2015 09:45 AM
Aug 19, 2015 06:55 PM
