19" wheels urgent
Old May 6, 2013 | 01:12 PM
Hdimashk's Avatar
Hdimashk has a spectacular aura aboutHdimashk has a spectacular aura about
19" wheels urgent
Hi guys I just found used work vs xx wheels and this is the setup THE SIZE IS FRONT 19X8.5 +51 REAR 19X11 +45 LUG PATTERN 5X130 the owner doesn't know which car they came off from, will these wheels fit a 996 turbo ? Please I need an answer ASAP thx guys
Old May 6, 2013 | 02:02 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
Those rears will most likely fit, but I think the fronts would need a spacer. My bbs fronts are 8" fronts with 56 offset, and they need a spacer so they don't touch my coilover. If these are half inch wider, I think if would be close.
Someone else should confirm, because I'm not 100% sure.
Old May 6, 2013 | 03:53 PM
SamboTT@ByDesign's Avatar
Look like a 997TT set. 15mm spacers all around for aggressive fit. Or 15mm rear and 7mm front.
I have a new set of 4-15's with bolts if you need.
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
