044 bosch fuel pump
Old Jun 2, 2013 | 06:35 AM
Hdimashk's Avatar
Hdimashk has a spectacular aura aboutHdimashk has a spectacular aura about
044 bosch fuel pump
Guys I need some info, can I replace the 044 bosch fuel pump with the oem fuel pump coz mine is ruined
Old Jun 2, 2013 | 07:30 AM
ttboost's Avatar
It's not the same pump. Why wouldn't you replace your 044 pump with a new 044 pump? It's only $150 and should pop right in?
Old Jun 2, 2013 | 07:36 AM
Hdimashk's Avatar
No my oem fuel pump is ruined and I want to replace it
Old Jun 2, 2013 | 07:40 AM
ttboost's Avatar
Best to use another OEM pump. Simple fix. 044 pump will not go in that spot...at least very easily. Pull your pump asembly out..you'll see the "Octopus". Do a search here for fuel pumps...
Old Jun 2, 2013 | 07:42 AM
It will go in there. Gotta trim some plastic Cuz 044 is wider.
#TeamAIM
Old Jun 2, 2013 | 07:44 AM
ttboost's Avatar
Exactly...not a "bolt in". You need to mod it to fit..not sure how handy the OP is and if his mods necessitate an 044 pump.
Old Jun 2, 2013 | 07:45 AM
Hdimashk's Avatar
So its a replacment for the oem fuel pump?
Old Jun 2, 2013 | 07:46 AM
ttboost's Avatar
I'm out...
Old Jun 2, 2013 | 08:25 AM
Hdimashk's Avatar
I need to know if it can be used as an oem fuel pump or not? Where can i buy oem fuel pump online?
Old Jun 2, 2013 | 08:28 AM
ttboost's Avatar
Read the last 8 posts. It CAN be used., but you need to hack up your stock basket. We are not sure if you are willing to do that. If your car is stock or very lightly modded, a stock pump is adequate, and very easy to replace.
Try Suncoast...or Sunset...not sure who else...
Old Jun 2, 2013 | 10:01 AM
johnspeed's Avatar
You can always add on the 044 in the future if needed..
adnanm3
Nov 22, 2023 02:43 AM
pwdrhound
Sep 13, 2016 10:44 AM
XLR82XS
Oct 5, 2015 07:02 AM
geetee
Cayenne
Sep 11, 2015 06:35 PM
