Mass Air Flow Sensor Questions
Old Jul 31, 2005 | 04:43 PM
Ruiner's Avatar
Originally posted by MARKSKI
I think its the plugs. I currently switched my setup and Im boosting to 22 psi(1.3/1.4) bars and Im going thru plugs lke crazy. I swithced them twice in 1 month. what happens is under full load like in 4rth at 5k oh higher the car stutters/ hick ups(as if out of fuel).
At 22psi, it sounds more like spark blowout rather than fouled plugs. You might want to look into that and gap the plugs down a bit. I had the same problem with my 3000GT VR-4 after raising the boost (as do most VR-4 owners).
Old Jul 31, 2005 | 04:50 PM
Zippy's Avatar
What's an appropriate gap for 1.3 - 1.4 bar????
Mike
Old Jul 31, 2005 | 05:04 PM
Ruiner's Avatar
Mike
I'm not sure what stock plug gap is at. Ideally, you should use the largest gap that does not create spark blowout with the boost setting you use.
For example on my previous turbo car, a 3000GT VR-4, the stock spark plug gap is between 0.039 to 0.043 in. The plug gap should be decreased to between 0.028 and 0.034 in. for running higher than stock boost levels.
Ken, are you getting stock blowout? Perhaps. Are you running lean and timing is being pulled? Perhaps as well. Are the recent plugs that you pull fouled? If they are fouled (very dark), then you are probably running too rich. If they are white, then you are probably running too lean. It could be any number of things.
Old Jul 31, 2005 | 05:12 PM
ebaker's Avatar
ebaker is infamous around these parts
Stock plugs are gapped at .026 - .032. The electrodes are so thick that they're very difficult to adjust.
Old Jul 31, 2005 | 05:54 PM
Ruiner's Avatar
Wow, that's low. It's probably not spark blowout, then.
Old Jul 31, 2005 | 06:30 PM
ebaker's Avatar
I think the side gap helps prevent spark blowout too. However since they're not platinum the gap will increase with use.
Old Jul 31, 2005 | 07:33 PM
it takes once to overboost to foul a plug. I have a manual boost controller and billet 1 bar actuators(wastegates).. these things kick out 1.6 bars if I let them. all this was happening when I still had a problem staying under 1.4 bars. Now that I use a manual boost controller I can dial in exactly what I want boost to be. its a $35 unit.
b4 whe I kept blowing the plugs I was boosting 1.5 regularly.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 5, 2005 | 03:30 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Originally posted by KPV
Dock,
Great to hear from you! I hope all is well down there! Are you 7up for a "round two" on the Tail?
All is well in Hotlanta.
TOD?? We really do need to have another go at it. Maybe this fall?
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
