60-130 techniques
Old Jun 6, 2013 | 08:04 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
60-130 techniques
I am picking up a VBOX SPORT tommorrow and would like suggestions on the best techniques to get the best times 60-130 TIMES.
IE: I have read some have got the best time in one 4th gear pull (I still can't figure out that out!), others from 2-4th, taking 4th to red line etc.
Thanks in advance for the advice.
Bobby Ali
ba
Old Jun 7, 2013 | 04:52 AM
ttboost's Avatar
Start at around 35-40mph and floor it, never hitting the limiter in any gear. If you start in 2nd, you have 2 shifts to perform, if you start in 3rd, 1 shift. You can also start in 4th and don't shift at all. This is where you will find that quick spooling is your friend. Go out and experiement. Shifting can cost you anywhere between 1 tenth and 3 tenths, depending how quickly you shift. I've found that starting in 3rd with 1 shift netted my best times.
Old Jun 7, 2013 | 06:55 AM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
considering your turbos i would start at 40mph and do 4th only, for sure 2-3-4 will be slower and a 1shift try 3rd-4th will make sense but i see it slower, try shifting earlier as your turbos dont make power up on top, test at different rpms and compare
make sure you are at full boost when hitting 60mph, traction is a limiting factor
remove all the weight you can, shift fast, get good fuel, colder weather will help, negative slope if possible
Old Jun 7, 2013 | 10:38 AM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
DO it going down a hill, that will help
Old Jun 7, 2013 | 02:53 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Go down hill!!! Full boost at 60, quick shifts and dont let off until 140mph.... This run has so many variables that come into play. Hopefully the sun moon and stars all align for you.
Old Jun 7, 2013 | 08:46 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Good Luck buddy. There are a lot if trick to a great 60-130. Plan on using the 407?
Bobbyfali
Jul 31, 2017 01:28 AM
TOGWT
Detailing
Sep 18, 2015 05:03 AM
