245/35 997 Wheel on 996
Old Oct 5, 2013 | 07:55 AM
regrossman's Avatar
regrossman is a jewel in the roughregrossman is a jewel in the roughregrossman is a jewel in the rough
I'm putting 997 turbo wheels on my 996. I have the factory shocks with H&R springs. This did not clear the spring perch at 25.8" diameter. With a 7MM front spacer it clears and doesn't rub anywhere. A 15MM front spacer provided much greater lower perch clearance and the wheel is flush to the fender but made it rub on the front radiator bump and the front back lower fender area.
I've seen some posts of 245/35R19's just bolting on but I see otherwise so FYI.
Old Oct 6, 2013 | 02:42 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
could be difference in sidewall dimensions brand to brand.
Old Oct 6, 2013 | 08:29 AM
regrossman's Avatar
Maybe the Pilot Super Sports run wider then normal.
Old Oct 6, 2013 | 01:32 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
PSS's have a very square sidewall and can fit a lot tighter compared to the same size pirelli for example due to the different designs of the sidewalls.
2lflat4
Nov 18, 2019 05:05 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
