Purchased a Porsche GT2 Clutch & Pressure Plate with 964 RS Flywheel..need help
Old Nov 6, 2013 | 12:48 PM
silence's Avatar
silence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud ofsilence has much to be proud of
About to put this in, but realized I don't have the flywheel bolts.
Can anyone provide the part number, and anything else I may possibly need outside of the clutch/flywheel assembly?
Thanks for the assistance.
Old Nov 6, 2013 | 12:56 PM
VAGscum's Avatar
You will need a 964RS sprung clutch disc, the longer TO bearing guide tube, Different TO bearing.
If you look in the knowledge sub forum you will see a parts list with part numbers.
Old Nov 6, 2013 | 01:56 PM
silence's Avatar
THanks.
Edit - Here's what I found from your post.
RS LWFW conversion parts list
Clutch guide tube: 950 116 813 30
Guide tube screws: 900 270 055 02 (2 ea)
Starter ring gear: 964 114 143 31
Throw out bearing: 944 116 080 01
Flywheel bolts: 928 102 151 01 (9 ea)
Flywheel: 964 102 239 31
Pilot Bearing: 931 102 111 00
Pressure plate bolts: 999 510 015 02 (9 ea)
I imagine the flywheels bolts needed are the ones listed?
Old Nov 6, 2013 | 02:44 PM
VAGscum's Avatar
Those are the ones.
COBB Tuning
Jan 1, 2025 09:02 AM
joseph_number1
Jul 19, 2018 05:45 PM
TrackOne
Aug 20, 2015 12:56 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
