Battery Replacement/Radio Code question
This I am sure is not a smart question, but I could not find a clear answer after searching for quite a while. I recently purchased an 03' 996TT. I need to change the battery. I have no problem with changing the battery (I also have a 993). The question I have is related to the radio. My 993 has a 4 digit radio code. I have this number is a very safe place and I have had to use it a number of times throughout the years, recently with a battery change.
I have read that the 2001 and 2002 996tt models also need the 4 digit code. But I am not so clear on if the 2003 and later models require or need a radio code.
I need to replace the battery in my 03' and I was never given a radio code. Do I need to worry about this, or will it reset itself?
Thank you
Thank you
Jul 29, 2019 11:13 AM
'02996ttx50
Aug 26, 2015 05:56 AM
