How do you change Fog lamps
Hey gang,
I just bought a pair of PIAA H3 replacement bulbs for my fog lights...
Thought it would be an easy pop out and replace...I found a couple of rubber gromits behind the front compartment panel, but no easy access to the bulbs...does the light assembly have to come out ?
Before I get too far into it, could someone describe how to do it.
Another thing to be careful of is the plastic inside the headlight assembly as it is quite brittle and will snap if you are not careful with it. Other then that it is a pretty straightforward swap. Good luck.
ECS Tuning - VW
Sep 2, 2015 12:58 PM
