Black smoke for tail pipes at first start up
Old Feb 26, 2014 | 01:50 PM
Gsxryder415's Avatar
Gsxryder415 is infamous around these parts
I am getting a cloud of black smoke when starting the vehicle. Only occurs on first start up after it's been sitting for a couple of days. Recently the low oil level light came on. I spoke to someone who recommended switching to Mobil 1 5/40 which may help. Any input on this would be great. Thanks in advance.
Old Feb 26, 2014 | 02:22 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Are you talking about a big cloud of smoke that comes out or a little puff of smoke at cold start? If its a little puff, its normal. If the low oil light is on, add some oil. Its unlikely you are in danger of running low as the car holds a lot of oil but best to keep the oil level around the middle bar on the dash readout.
Old Feb 26, 2014 | 03:04 PM
johnspeed's Avatar
Black smoke is not oil..
Blueish white is oil.
Black is rich fuel mixture.
Old Feb 26, 2014 | 03:26 PM
rmc1148's Avatar
Correct rich fuel mixture I would have a good shop take a look.
Old Feb 26, 2014 | 03:50 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Unless you are tuned then expect black smoke on first start
Old Feb 26, 2014 | 04:08 PM
rmc1148's Avatar
Mine is not tuned and no black smoke?
Old Feb 26, 2014 | 04:52 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
leaky injector?
Spark plugs struggle to ignite?
Define black...I've heards tons of people say black when they are really meaning variations of grey.
Old Feb 26, 2014 | 04:59 PM
johnspeed's Avatar
Some maps are rich on initial cold start up.
Old Feb 26, 2014 | 05:26 PM
I'd say its a blueish black and call it a puff- but enough to travel into cabin when starting in the garage with drivers window rolled down. Other ppl have told me it's normal as well. Should I be concerned?
Old Feb 26, 2014 | 05:29 PM
stilov's Avatar
Meh. Is it just once in a while?
I bet it's oil.
Old Mar 5, 2014 | 06:17 PM
agy2k2's Avatar
agy2k2 is infamous around these parts
I have read that this is normal for these
Old Mar 7, 2014 | 09:35 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Mine does it constantly. It's oil. I hate it to, looks like a junker starting up
Old Mar 7, 2014 | 10:19 AM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Mine does it 2 out of 10 start ups.
Old Mar 7, 2014 | 11:15 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Mine used to do it after parking on a transverse slope . The cylinders can hold oil in them and it produces some smoke on start up. Some times it might not even do it. But.....it is quite common.
So long as;
Your not using too much oil,
You not getting smoke when driving,
It doesn't do it every time you start especially on the flat,
The smoke is actually burnt oil and not fuel. ( Type of tune dependant. Good tunes should not do this.) A leaking injector will give a P code as the O2 sensors should pick up the issue.
Its easy to determine if the smoke is fuel or oil, just get some one to start the car for you and have a smell of the smoke, your going to be able to instantly tell the difference between fuel and oil.
Hope that helps a bit to supress the paranoia that these cars have a habit of causing.
Frank.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Sep 14, 2015 06:42 PM
