130 mm rods turbo 996
Old Mar 11, 2014 | 12:27 AM
m5q8's Avatar
m5q8 is infamous around these parts
Hi
I have pauter 130mm it is taller than the stock 127mm rods belong to my friend and he give it to me free
Can I use it for my 996 turbo stock crank ?
what is the custom piston size and liner with not expensive price?
what everybody will do with this rods ?
Old Mar 11, 2014 | 08:59 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I think those are for a 997 GT3 or earlier 2.2, 2.4L l motor. They are too different in too many ways to work on a 996T crank. The crank journal diameter is different for starters.
Old Mar 11, 2014 | 05:13 PM
m5q8's Avatar
Somebody say that I can use custom pistons from je or cp for that length
Old Mar 11, 2014 | 07:55 PM
nick49's Avatar
Yes you could but the rods will not even fit the crank as I mentioned previously.
The big ends on the 130 are smaller by 2mm and wider as are the small ends. It's much easier to buy the right parts rather than try to make free parts work that are wrong.
Longer rods will present their own issues even if a custom piston is made with higher pin. A higher pin often will be located in the oil ring area requiring a floating spacer that also acts as a pin retainer. This can cause issues itself.
Old Mar 12, 2014 | 03:15 AM
m5q8's Avatar
I think this rods came from 993 turbo..it will fit correct me please
Old Mar 13, 2014 | 04:04 PM
m5q8's Avatar
No new comment
Old Mar 13, 2014 | 08:11 PM
nick49's Avatar
I think 993 and 996 turbo rods are the same. Mock 'um up see if they'll fit. Then jump through all the hoops to have some special pistons made. Make certain the weight is within spec and the valve pockets are deep enough. Often times manufacturers like JE, Arias and others will send you a blank and it's up to you to do the final machining. Other times you must build the motor on paper and give the piston mfg a print of all the specs you desire. As you know, longer rods sometimes result in lower cylinder clearancing and other problems.
Are you the builder or going to have it built?
Old Mar 13, 2014 | 08:23 PM
m5q8's Avatar
Going to have....
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
