Installing a second air duct for the air box?? Dual snorkel.
I just saw this air duct on the evoms webpage. What are the chances of using this as a secondary air duct on the opposite side of the air box?
I added the link, but was unable to add a pic. http://www.evoms.com/EVOMS_Porsche_C..._p/cf996id.htm |
Originally Posted by awdbiturbo1
(Post 4069999)
I just saw this air duct on the evoms webpage. What are the chances of using this as a secondary air duct on the opposite side of the air box? I added the link, but was unable to add a pic. http://www.evoms.com/EVOMS_Porsche_C..._p/cf996id.htm
i have the a/p box for sale with the snorkel and k&n filter
2 Attachment(s)
I just fitted my AP, not too bad a job BUT sxtill think I need to get the snorkel lined up with the intake in the box better
https://www.6speedonline.com/forums/...ine=1395134289 https://www.6speedonline.com/forums/...ine=1395134289 |
Originally Posted by johnny.dangerous
(Post 4070616)
Use can use insulating foam,, as I did, same thing.
And trim the hole a little better to liner up. |
I need to force my airbox into the engine a little I think to get it to line up. Good tip about the rubber gasket on the stock snorkel !!!! I used some self adhesive trim we had lieing around.
Leave your stock air box and stock paper filter right where it is....in your car...the only benefit to removing it is going to fender well intakes....you'll have nothing but MAF issues...
Originally Posted by ttboost
(Post 4071485)
I've been tempted by the Agency Power upgrade... is it worth it? Does it basically just look cool? Does it give a noticeable power boost? Are the MAF issues real?
Originally Posted by antagron
(Post 4071571)
2 Attachment(s)
If anyone is interested in playing around with it, I've got this for sale for $100. Carbon Snorkel for the Agency power BOX. You could cut a second hole in your stock box and fit this on. (Might just keep it and do that myself!)
https://www.6speedonline.com/forums/...ine=1395241280 https://www.6speedonline.com/forums/...ine=1395241280 |
Originally Posted by TXTurbo996
(Post 4071609)
Running the box itself with the dual snorkel shouldn't give any MAF issues. The consensus is that using an oiled filter is what can cause issues. Keep the stock filter and you should be fine.
(Post 4071571)
(Post 4071654)
There is a video apparently on the K&N site of a MAF sprayed in K&N oil and not causing any issues at all, I would imagine a lot of issues with the MAF's arise from the fact a K&N is fitted when a map is installed and this finds the weak spots in old MAF, put a new Bosch MAF in and you will have no problems, I have new MAF, K&N AP dual air box and no MAF issues.
