Help w/ 19" Tires for 996TT
Old Aug 28, 2014 | 01:49 PM
  #31
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Bon Bon - Thanks for the input. Do you know what size (19x11/19x12?) and rear offset. Curious to see what my specs are in relation to yours. Thanks!
Old Aug 29, 2014 | 02:19 PM
  #32
Bon Bon's Avatar
Registered PM
Bon Bon is infamous around these parts
Well, the offset I'm running is aggressive, but I'm not complaining that I had to roll the arch lips. The problem I have is with the physical top of the arch, it rubs across the entire width of the tyre given a heavy enough compression such as the foxhole, and the issue with the tyre being cut was with metalwork mid-arch, not on the outside.
11j et27 offset Cargraphics, I don't feel 11j is optimal for the 305 cup either, since I have a ton of sidewall flex under heavy cornering. 997 gt3 runs 305/30 on a 12j so if I stay 19" I will at least go to a 12j. I feel it needs it, at the moment I have to run pretty high pressures to retain stability with the cups.
As for ride height, I've played around with it a bit, here's a photo of how it was after the nurburgring...
And now after goodwood, lowered in the rear a little for a flat circuit, although cornering so a little distorted....
Old Aug 29, 2014 | 02:47 PM
  #33
Sabie's Avatar
Sabie is infamous around these parts
Originally Posted by Wealth Manager
Winner winner chicken dinner..........
i run 235/35 and 305/30
Hi Wealth Manager, no issues with PSM and AWD?
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Fabspeed Motorsport
Sep 2, 2015 12:04 PM
L.A.P.
Aug 23, 2015 11:48 PM
