Weird missfire problem after power upgrade
Old Apr 21, 2014 | 03:51 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Originally Posted by TabooPc
My plugs are the denso iridium ik22.
I had no luck with these plugs. Ran a lot worse than the platinum Densos. Just my experience.
Andreas
Old Apr 21, 2014 | 06:46 AM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Yeah. If it was the plugs it would be on all cylinders. Or just one.
No other codes besides the missfire. I clear the missfire codes and they come back after 30 seconds of driving.
Ok since you are catless disregard the o2s for now ,ots not that. Check all the vacuum lines again but since it is intermittent and on one bank it sounds like something electrical. Double check cam sensor for that bank . The ground strap is on chassis above passenger turbo . It grounds the engine to chassis.
Old Apr 21, 2014 | 08:16 AM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
did you measure the plug gap? mine are gap at .024 before 0.28 and i had a lot of misfire
Old Apr 21, 2014 | 08:27 AM
Not yet. It is something I plan on doing soon. There is no fuel smell though.
That's the first thing you should have done.
Old Apr 23, 2014 | 06:33 AM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
For future reference; the problem was fixed by changing the bank 2 o2 sensor (the sensor responsible for cylinder 4, 5, and 6). Since the tune is now mafless, the o2 sensor is relied upon more than others.
Thanks for everyones help!
Old Apr 23, 2014 | 07:56 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Glad to see problem solved. By 'changing' you mean replacing the O2 sensor, right? (I've seen people swap O2s to see if faults follow the part to the other side)
Henry
Old Apr 23, 2014 | 08:35 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Wow i forgot about the 02 sensor this is great info. Im glad you fixed it but would like to know how did you guys find the issue????
Old Apr 23, 2014 | 09:19 AM
TabooPc's Avatar
Henry
Luckily my buddy had two spare o2 sensors... He had only used them a few hundred miles. I figured I'd plug a new one in and try it out. Vwala.. Problem gone.
It goes to show how important your o2 sensors are for driveability. Mine are most likely 5+ years old before I switched to the new ones. It took a mafless tune to figure out they were (ok only one was) bad. The car is smoother than it has ever been. Something to look into for cars that arn't running perfectly.
Old Apr 23, 2014 | 03:56 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
OP. have you put some miles in with the new O2 sensors ? I had that happen last year and replaced with brand new sensors, had problem come back 6-700 miles later, swapped them and problem would come up intermittently, then I would get left side O2 codes. Turns out it was a crack in the weld of the cats that were only noticable once warmed.
Old Apr 23, 2014 | 04:14 PM
TabooPc's Avatar
Its funny you say that. I just tested the car again today (which before I had just driven around a little) it missfires badly once I hit 1.2bar (1.4 bar being my peak). This time the missfires are coming from the other bank. Im going to switch my o2 on the other side (bank 1) with a newer one now. If that doesn't work, ill look for some cracks.
Old Apr 24, 2014 | 10:03 PM
TabooPc's Avatar
Update: I changed my plugs, and gapped them to 0.025" (0.63mm). This worked! The car no longer missfires at wot. I assume the bad o2 sensor caused the plugs to foul from running rich.
Old Apr 24, 2014 | 11:08 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
That's great! So you didn't end up replacing O2's on Bank 1? Do you know if your bank 1 and bank 2 AFRs are pretty equal?
Old Apr 25, 2014 | 12:11 AM
TabooPc's Avatar
I haven't done much dataloging since the fix (it was today and I haven't driven much since). I did replace the bank 1 o2 the previous day and it had no effect.
Hopefully my afr's are the same now!!
Old Apr 25, 2014 | 02:06 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Which plugs did you end up going with?
Old Apr 25, 2014 | 06:18 AM
forcefed1's Avatar
forcefed1 is infamous around these parts
when your car misfires at WOT. does it make a muffled popcorn popping sound?
I have been fighting a problem that I think is missfiring not Knock.
I have heard knock and it was much louder of a sound. my durametric does not show misfiring counts though.
I changed my spark plugs but did not regap them. and the problem lessoned some.
However this misfiring is not something I Feel. I really just hear it and it's only in above 1.0 bar mostly if the engine is colder and the waterinjection is on.
do you hear your misfire or just feel it?
