FVD-Brombacher ECU upgrade and California Emissions
Old Apr 29, 2014 | 11:43 PM
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
I'm looking at purchasing an '02 996TT with the FVD-Brombacher ECU upgrade from out of state (MO). Since I didn't do the upgrade, I'm assuming loading the stock map for Californai emissions, then re-loading the FVD-Brombacher map afterwards would not be an option?
Am I opening myself up for a big bill in the form of a new factory ECU?
Opinions and suggestions welcome
Old Apr 30, 2014 | 06:49 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Just to go out on a limb here but I don't think a tune would fail emission even for here in CA unless cats have been deleted and you upgrades that make you fail visual inspection then the actual test itself. Since emission testing is done in the range of 2250-2700 rpm, I don't think any tunes affect standard emission in that range especially since there are no loads during the test.
Was it an actual ECU swap out or was it an ECU port flash ?
Old Apr 30, 2014 | 08:29 AM
Rhonda@FVD's Avatar
Premium Sponsor
Rhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond repute
Can you pm me the vin # of the car? I can check what program you have. Typically we would have sold a durametric cable to the original owner or the car would have been flashed by one of our dealers with the same cable. Ask the owner if the FVD flash cable comes with the car. Then you can simply flash the car back to stock and pass the emissions.
However it depends on how long ago the software was written so the Vin # can help me determine exactly what you have. By the way you don't need to purchase an ECU at all. All of our flashes can be overwritten by the dealer with the PIWIS if you needed to.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Old Apr 30, 2014 | 09:11 AM
Highlander's Avatar
Aha! I think I get it. The listing states "FVD Brombacher ECU upgrade w/ programmer". So I guess that would allow me to put the stock tune back on if I need to.
AFIK, there are no physical changes, just the ECU programming.
Things are looking promising...
Old Apr 30, 2014 | 10:09 AM
Rhonda@FVD's Avatar
Premium Sponsor
Yes. If the owner gives you our My Genius programmer you can flash back to stock as the stock file resides on the programmer. But if they used the Flash Client (durametric) cable make sure that the owner emails you the original and tuned file or has it on a flash drive or disc with the car.
Rhonda Roxburgh
+1-954-571-2050 x 1
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
