Recommendations sway bars for x73 setup
Long time no see EZ1. You could go with just the rear GT2/3 sway bar and experiment with running it full stiff or even less. You need curved drop links to run the front GT2/3 front sway bar and you could PM some of the sponsers here for leads on where you could grab some.You could also go for the H&R sway bars, they are solid and not hollow, but they come with all that you need to adjust the degree of stiffness that you need. Hope you also installed the stiffer motor mounts which should have come with the X73 package.
proTUNING Freaks
Sep 15, 2015 07:28 AM
AdamNoone
Sep 3, 2015 04:15 PM
