996 turbo issues after changing dv valves
Old Jun 10, 2014 | 02:36 PM
996737fly's Avatar
996737fly is infamous around these parts
Need a bit of help !! Replaced standard dv valves one was split with 14 psi ones Car has dms remap and was pulling 1.0 bar - 1.2. Now only spiking at .8 whirring noise from right hand side side and drives like it has a broken actuator rod ( it hasn't ) Maf changed n75 changed plugs changed rods free. Any pointers greatfully received .
Cheers Fraser
Old Jun 10, 2014 | 08:08 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
What do you mean by "one was split with 14 psi ones"? Sorry, I can't understand that.
Are you sure its not some other hose, like an intercooler hose? Have you adjusted your actuator pre-load lately? The preload being too low can make an air rushing sound during normal driving.
Old Jun 10, 2014 | 08:44 PM
996737fly's Avatar
Sorry. One of the standard Bosch diverter valves was split . These were replaced with the upgraded 06A145710N part number. These are a stronger valve and require more vacum to open. I have tested before fitting. I know there must be a leak somewhere as it now appears the vac pressure is not strong enough to open them . The car now runs as if only one turbo is spooling. I was looking for pointers to which hose / hoses may have failed and if this would cause these symptoms . The car ran quicker / pulled more bar with the old perished dv fitted !!
Fraser
Old Jun 10, 2014 | 08:56 PM
rmc1148's Avatar
Check your vacuum hoses for splits and make sure they are seated properly some people plastic tie to secure. Do a boost leak test.
Old Jun 10, 2014 | 09:10 PM
'02996ttx50's Avatar
..and 710n's shouldn't function differently.. all it takes is an i/c c clip to pop a hose so agree with testing. but always start where you stopped. switching out dv's is revisit #1.
Old Jun 11, 2014 | 12:27 AM
TabooPc's Avatar
The engine vacuum opens them when you come off boost. If you had a bad vacuum leak then they would open slower. It sounds more like a boost leak. Boost is what holds them shut.
It seems unlikely that they could cause something that big. Did you take the hole y-pipe out to do the change? Maybe you didn't reconnect the hose that goes to the turbo intake plenum?
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
Aug 19, 2015 06:55 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
