New Member Help - AWD Question!
Old Jun 25, 2014 | 08:42 AM
gregp714's Avatar
gregp714 has a spectacular aura aboutgregp714 has a spectacular aura aboutgregp714 has a spectacular aura about
Hello!
I just bought a 2003 996 Turbo yesterday evening - I'm stoked. During all of the test drives she drove excellent, but when taking a tight 180 degree sweeping freeway on ramp at speed (accelerating) I could feel a slight grumble/shudder under my butt and in the steering wheel. It also made this same grumble/shudder when making a U-turn while getting hard onto the gas at the end of the turn.
Question - can you feel the AWD/PSM system working? Would it cause this grumble/shudder while sharp turning and accelerating? Other ideas?
Straight line driving no issues. As a noob to Porsche AWD I might just be a little touchy to all the new noises and feelings of the car.
Car has 59,000 miles and otherwise checked out with the mechanic when I had the PPI done.
Thanks in advance for the help!
Old Jun 25, 2014 | 09:30 AM
DSCOFF's Avatar
DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !
I'm fairly new to Pcars as well, but what you're describing doesn't sound normal. I don't ever feel or hear any grumbling/shuddering. AWD on these cars is seamless and PSM you'd notice the light on the dash if it kicked in.
Old Jun 25, 2014 | 09:40 AM
wross996TT's Avatar
Check to see if your tires are rubbing. There are lots of possibilities...
jumper5836's Avatar
jumper5836 has a spectacular aura aboutjumper5836 has a spectacular aura about
Wheel bearing? I don't think AWD would come on in any of the instances your talking about. Power steering pump my grumble at full lock.
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Could be something as simple as a bad CV joint or something worse like a differential problem. I would definitely have it checked out.
Old Jun 25, 2014 | 09:58 AM
rmc1148's Avatar
Agree with IITURBO have cv joints looked at and diff fluid etc.
Old Jun 27, 2014 | 05:55 PM
gregp714's Avatar
UPDATE:
Worn transmission mount was the problem. Thanks to this forum I found the answers I needed.
albert@velosdesignwerks
Bentley
Dec 24, 2018 09:46 PM
Enemy
Oct 24, 2015 04:14 PM
Lamborghini
Aug 22, 2015 09:03 AM
ModBargains
Aug 20, 2015 12:28 PM
