headers
Old Jul 2, 2014 | 09:55 AM
Drew959's Avatar
Drew959 is a jewel in the roughDrew959 is a jewel in the roughDrew959 is a jewel in the rough
Originally Posted by Steve Jarvis
On other cars I have owned, the header ports were actually larger than the exhaust ports on the head. As long at the gasket matches the exhaust ports on the head, you shouldn't have a problem.
Later, Steve
Agreed. If this is the case you're good to go. But if the header ports are smaller than the head/gasket you have a problem.
Old Jul 2, 2014 | 05:42 PM
cjv's Avatar
cjv
Moderator
Originally Posted by Drew959
Care to explain? I don't see the issue of port matching gaskets.. I've done it with no Ill effects
Sure, not leaving a certain lip at the top of the header results in harmonic distortion. These harmonic waves will travel back through the valve train and result in a slight loss of power.
This isn't new in exhaust science.
Old Jul 2, 2014 | 07:33 PM
johnspeed's Avatar
Acts like an anti reversion cone in the exhaust pipe flange
Old Jul 3, 2014 | 08:53 AM
Drew959's Avatar
Interesting. Have any sources? I've been reading about backpressure and scavenging but haven't found any articles about lips in the header affecting harmonics. Thanks
Old Jul 5, 2014 | 08:26 AM
cjv's Avatar
cjv
Moderator
I believe one source is A. Graham Bell's book, Forced Induction and Tuning
Old Jul 5, 2014 | 11:09 AM
johnspeed's Avatar
Variable cam timing motors are not as critical on that issue as normal cam timed motors and even then it usually at trade off in power in certain RPM levels ,,lose some low end gain some high..
All the tech stuff I saw and read in my years > a lot of old info doesn't address newer technology like variable timing,,D Ports,etc.
Old Jul 5, 2014 | 02:03 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Stock headers, if memory serves, are good for 600 to the wheels.
I'd put the stock headers back on and use that header money for new turbos.
Old Jul 7, 2014 | 10:13 AM
Undercover Tuning's Avatar
Undercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond repute
contact me if you need to get new headers or gaskets sourced
undercoverperformanceinc@gmail.com
lawerence
Studio RSR
BMW Vendor Classifieds
Nov 10, 2015 07:07 PM
gadgetman
Sep 21, 2015 06:55 AM
Sep 3, 2015 04:56 PM
shifter_
Sep 2, 2015 03:33 PM
