What else to change when changing brake pads?
Old Jul 9, 2014 | 09:06 PM
brichacek's Avatar
brichacek is infamous around these partsbrichacek is infamous around these parts
When changing brake pads, what else should I change?
From what I've read, it seems like the sensors are a good thing to have on hand as they break easily. Rotors is seems like don't have to be changed too often so long as they are not worn or cracked.
Old Jul 9, 2014 | 09:09 PM
32krazy!'s Avatar
flush the fluid if it has been 2 yrs or more
Old Jul 10, 2014 | 06:05 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
Measure the rotors for thickness. Minimum is stamped on them. If you have noticed any pulsating pedal or steering wheel shake at all when brakes are applied, measure for run out.
Old Jul 10, 2014 | 06:07 PM
32krazy!'s Avatar
also a good time for braided stainless brake lines.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
