PSM, ABS, But No CEL's???
Old Sep 26, 2005 | 04:19 PM
Big Carrot's Avatar
Junior Mint
Big Carrot is infamous around these parts
Out driving my car this morning, and it just cut out a couple of times then died. PSM and ABS lights were on, but no CEL. I turned the key off and back on and it started up. This happened several times and it restarted every time. Well I was headed home, and it just died and wouldn't restart. Called Porsche, and got a tow truck on the way, and while I was waiting I tried to start it again and it worked. It died a couple more times on the way home, but I got it here. I just hooked my scanner up and it said there were no codes at all. Could this be a MAF, or would I also have CEL's?
Old Sep 26, 2005 | 08:19 PM
MBailey's Avatar
I would agree, I bet its the MAF.
Old Sep 26, 2005 | 08:25 PM
Big Carrot's Avatar
Junior Mint
Even without a CEL? I thought for sure it would throw a code, but I'd love to be wrong.
Old Sep 26, 2005 | 08:26 PM
BobbyC's Avatar
BobbyC is infamous around these parts
possibly fuel pump...have fuel line clamps checked.
Old Sep 26, 2005 | 08:37 PM
wross996TT's Avatar
Doubt it is the MAF that caused it!
Old Sep 26, 2005 | 09:13 PM
ebaker's Avatar
ebaker is infamous around these parts
It would be nice if you could scan for a code the next time the light comes on - before you turn off the key. There is a tech bulletin on fuel pump hoses coming loose in the gas tank. Could also be something simple like a clogged fuel filter. Since many gas stations in DFW ran low on gas you might have gotten some crud from the bottom of a gas station's tank. Did you buy gas since last Thursday?
Old Sep 26, 2005 | 09:34 PM
Ruiner's Avatar
Chipped or not?
Old Sep 26, 2005 | 10:09 PM
Big Carrot's Avatar
Junior Mint
I did buy gas, and it is chipped. If it had a code, the CEL would be on, correct? Wouldn't have also been saved in the memory?
Old Jan 25, 2006 | 01:15 AM
trev0006's Avatar
trev0006 has a spectacular aura abouttrev0006 has a spectacular aura about
did you fix the problem? and if so what was it?
Old Jan 25, 2006 | 05:27 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
it was MAF problem, mine have the same PSM and ABS light before. Replace new MAF will fix the problem
Old Jan 25, 2006 | 08:00 AM
PorschePhd's Avatar
I would bet there is a pending code and it is not the MAF. Go have the pendings pulled by a PST2 and see what they say. I suspect something other than MAF here.
Old Jan 25, 2006 | 09:20 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
I believe Big Carrot has the Upsolute programing and has problems with cold weather. Stephen I know you worked on a few of these programed cars. What`s up? Is it related to Upsolute?
Old Jan 25, 2006 | 12:16 PM
trev0006's Avatar
What could it be? when I unplugged the MAF wire the car idled perfect and totally drivable to the dealer.
Old Jan 25, 2006 | 02:22 PM
Ruiner's Avatar
When you unplug the MAF, the car will fall back to a "safety" mapping (usually runs a little rich to be on the safe side) table that was already programmed into the car's ECU. It uses an pre-programmed educated guess for airflows at various RPMS, so to speak, in order to let you get the car back to the dealer.
Old Jan 25, 2006 | 05:09 PM
trev0006's Avatar
so if the car runs smooth on the safty mode then there shouldn't be a major problem right? and MAF could be failed.
