Dyno Results 996 GT2
Old Jan 30, 2015 | 11:57 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Not a scientific data point...
but my GT2 did 474rwhp @ 1.0bar:
dynojet
93 octane tune
exhaust (200cell cats)
stock wastegates
3.8 fpr
stock intake
stock ICs
Definitely do some logging / boost leak checking
Old Jan 30, 2015 | 12:00 PM
SamboTT@ByDesign's Avatar
Originally Posted by gclasse
Do you mean boost, at the dash it was showing 1.2bar but I will follow the recommendation and do a boost leak test ASAP. I might also change the Internal WG.
Sorry i don't have a data logger, but will put it on the list.
Sorry yes, I corrected to "boost"
Something is bleeding off or pulling back after initial ramp up it seams.
Old Jan 30, 2015 | 01:19 PM
Pressure test the car...
data logs would be great and go from there...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 30, 2015 | 04:40 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
I will post in the classifed section a WTB durametric. Definitely need to start logging my runs.
Thank you all...
Old Jan 30, 2015 | 04:55 PM
Thank you all...
usually you buy a new one.. they get locked into the car... I doubt you will find one...
9.66
click to view
Old Mar 15, 2015 | 06:45 PM
gclasse's Avatar
Well, i did some upgrades on the car. The y-pipe was fabricated and the 4.5" Intercooler Outlets were replaced from 2.25' to 2.5" pipes to match the y-pipe..
Old Mar 21, 2015 | 09:53 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Thumbs up
Finally i put my GT2 on the Dyno to get some numbers..
Mods so far are:
Stock K24's (not really a mod!!)
GIAC Flashloader (Stock and Pump Program were tested) 91 Oct
EVOMS V-flow (Bosch MAF)
3" Custom Exhaust (no cats)
4.5" Custom Intercoolers / AP silicone Ducts
5 bar FPR,
What you guy think..?? what should be the next move???
GIAC Stock Program
GIAC Pump Program 91 Oct
Both Run Compared
First thing I would do is get rid of the intake you are using and put the stock box back in with a paper filter ASAP pm me if you want to know why
Cheers,
Tim
Old Mar 21, 2015 | 10:20 PM
vr4henry's Avatar
Same, nothing wrong with stock airbox.
Old Mar 21, 2015 | 11:13 PM
gclasse's Avatar
I have always heard good things about the stock unit.. Unfortunately i don't have it!! Anyone with a stock air box unit willing to sell cheap!!
Old Mar 22, 2015 | 12:06 PM
BLKMGK's Avatar
Occasionally you can find parts like the on eBay. Have you replaced intake piping yet?
Old Mar 22, 2015 | 05:42 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Going mafless here, so no need for stock airbox. IM me if interested. great numbers btw!
Old Mar 23, 2015 | 07:41 AM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
My car on the GIAC tune made the same power more or less with 93 octane with a near identical dyno chart as yours.
480 whp sounds about right from the GIAC tune
1. Upgrade your fueling and probably clutch
2. Mafless - I had all sorts of problems with the vflow MAF
3. Retune
Old Mar 23, 2015 | 09:37 AM
Good points on the MAF. Does the V-flow have the plastic waffle from the stock airbox in it? It smooths the flow to the MAF. You can even drive it without the MAF connected and see how it reacts.
Old Mar 23, 2015 | 10:40 AM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
3. Retune
That is likely an older version. Our latest K24 software makes well into the 500whp range on pump fuel (with exhaust), assuming the car is healthy. We've cracked 500 awhp on X50s using 91 octane fuel with our low reading dyno.
Old Mar 23, 2015 | 12:30 PM
gclasse's Avatar
Would that be my case also??
