O2 Bank 1 .80 Bank 2 1.0- Only at idle and warm
Old Feb 4, 2015 | 09:08 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
My post 02's are reading .8 on Bank 1 and 1.0 on bank 2 at idle only.
On load they are 1:1.
Brand new O2's, injectors tested and recalibrated, fuel pressure regulator set to 3.8. No vacuum or boost leaks.
The issue only shows at Idle. The problem only shows face once it warms up.
Thought it was a shot in the dark if anyone had an idea?
Old Feb 4, 2015 | 11:39 AM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
I've had / seen this issue aswell. I would reset your ecu, and then let it learn again and see what happens.
Is your fuel setup in one rail and out the other? Or split and into both and then out. I've always wondered if to much fuel flow at idle was causing and imbalance in fuel pressure at the rails.
Old Feb 4, 2015 | 12:11 PM
what does the tuner say... you have a highly modded car... it could be anything...
I would start by swapping 02s around... was it like that from the start or it happened recently...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 4, 2015 | 02:41 PM
If that was the case you would see issues on both sides i would assume.
Already did that and got new o2's also. We've trouble shot all the basics.
Originally Posted by Tony@epl
Plug in an airflow sensor... even if its not in the actual air flow and see what happen.
I will give it a shot thanks.
Old Feb 4, 2015 | 03:01 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Have you been driving through the rain, snow and ice puddles around Long Island by any chance ?
Old Feb 4, 2015 | 03:52 PM
Car doesn't leave the garage, in or after any bad weather.....
Old Feb 5, 2015 | 12:34 PM
wolfhedge's Avatar
Reason I asked is I got some weird readings after a few "slush" runs and when I dried it all out the next week it was normal..
Old Feb 5, 2015 | 04:18 PM
BLKMGK's Avatar
Filters and socks right off the turbos mounted low right? Froze one up maybe?
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 02:07 PM
007 Vantage
Oct 8, 2015 08:35 PM
Oct 6, 2015 06:13 PM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
