02 996 TT which turbos
Old Feb 16, 2015 | 10:21 AM
acmf74's Avatar
acmf74 is infamous around these parts
Hi
Recently picked up a 996TT.
How can I tell which turbos are on the car?
Non x50
Old Feb 16, 2015 | 10:24 AM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
If non x50, it left the factory with K16. If they have been changed at some point, you have to have someone look at them that knows.
Some look different from the outside, some don't and they only appear different on the inside.
Old Feb 16, 2015 | 11:12 AM
SamboTT@ByDesign's Avatar
If you can take the turbo inlet and exhaust off to take pics it may be the only way to be sure.
Old Feb 16, 2015 | 11:17 AM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Is the car heavily modded, why do you believe it doesn't have the stock turbos?
basically get under the car and take some pictures and post them...
Old Feb 16, 2015 | 08:46 PM
johnspeed's Avatar
HI,By any chance did you look under your front hood lid and check the sticker for the option codes ?
Old Feb 17, 2015 | 07:04 AM
'02996ttx50's Avatar
another way to "guess" .. is to see if your intercoolers are changed also. because no one is gonna do that, unless they have aftermarket ( or at least k24 ) turbos. just rub your hand on the i'c's under the rear wheel well, and if they are "rough" like a cheese grater? then you have the x50/gt2 i/c's. if the car doesn't have the x50 package, it won't have anything on the sticker bonnet related to engine upgrades as ( iirc? ) the x50 kit is the only power upgrade available from build, that might be visible on build sheet or bonnet sticker.
Old Feb 17, 2015 | 09:13 AM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Step on the gas.
.6 bar, you're probably stock K16.
>.6 bar, then do the homework.
Do you suspect your car was modded, or do you know for sure?
-V
Old Feb 17, 2015 | 10:10 AM
johnspeed's Avatar
Yes the intercoolers are a good way to tell ,,,
But back in those days others did switch them out and bought them from others that went on to bigger builds that had X-50..
Hopefully you have that sticker as I mentioned in an above post.
Old Feb 17, 2015 | 10:39 AM
K16s unless someone upgraded...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 17, 2015 | 10:41 AM
Undercover Tuning's Avatar
Undercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond reputeUndercover Tuning has a reputation beyond repute
Take a ride down to my shop in New Jersey, We can do a full mechanical inspection and tell you what you have and also help get you "better"parts and more power
Undercoverperformanceinc@gmail.com
Lawerence
BlackMarketRacing
Dec 3, 2015 10:46 AM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
