Clicking sound when starting car
Old Apr 1, 2015 | 09:49 AM
brichacek's Avatar
brichacek is infamous around these partsbrichacek is infamous around these parts
2002 996 Turbo. When I turn the key to start the car, the electronics in the car seem to the working fine. When I turn it to the start position, it sounds like it tries to crank for a second or so, and then all I hear is this clicking sound until I stop turning the key. I tried trickle charging the car for 24 hours and had no luck. Also tried one of those external jump start battery packs and same thing was happening.
The battery is relatively new, just over a year old. Could this still be a battery issue? Or does this sound more like an ignition switch problem?
Old Apr 1, 2015 | 10:00 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Clicking sound normally is a sign of a dead battery. I did read you have a new battery; however, it's not uncommon to have a new battery go dead.
What's the voltage after the charge? I'm going to assume you have cleaned the post and wires removing any corrosion.
Before you spend more time, money, checking the starter, electronics, etc., your best bet is to take your battery to a shop and have them check it for you.
Old Apr 1, 2015 | 12:53 PM
rmc1148's Avatar
Good advice!
Old Apr 1, 2015 | 01:54 PM
'02996ttx50's Avatar
the trickling suggests it isn't a battery issue which given the cars propensity toward devouring any/all available juice. you're right to look toward the switch.
its tough to diagnose beyond that w/out more info? do you have cels and a reader? that might help. i second testing the battery as noted already tho...
but if you're going to throw a part at it? its a vw/aud/986/996i $6 switch on amazon
Old Apr 1, 2015 | 02:20 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
I had the same issue because I didn't drive the car enough. Took the battery back to be checked. It was fine, but needed to be charged. I purchased a Porsche trickle charger which plugs into the lighter and I have not had a problem since. And that was about 4 years ago.
Old Apr 2, 2015 | 11:49 AM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
These cars must be on a trickle charger if they sit more than a few days. Significant amps are pulled by the electronics even when static. I had a battery for over 5 years and mine was driven maybe twice monthly at times.
Old Apr 2, 2015 | 01:10 PM
32krazy!'s Avatar
check starter solenoid
Old Apr 2, 2015 | 06:32 PM
brichacek's Avatar
Going to plug in the durametric tonight and see if that sheds any light on things.
How do I go about checking the starter solenoid? Also, someone mentioned the possibility of a corroded ground strap. Where exactly is this located in the 996 Turbo? I can't find anything on that
Old Apr 2, 2015 | 06:37 PM
32krazy!'s Avatar
pas side below the motor to the frame. its old school but you turn the key on and cross the posts on the starter with a screwdriver. make sure its in neutral!
Old Apr 2, 2015 | 06:56 PM
rmc1148's Avatar
Check connections are clean and tight at starter also, good advice from Krazy.
Old Apr 5, 2015 | 07:47 PM
brichacek's Avatar
Ended up being the battery after all! Ended up buying an Optima Yellowtop and made my own strap to fit it in place
brichacek's Avatar
The only thing is, that after my battery swap my speakers no longer work. Has anyone ever had this issue? I have an aftermarket stereo (Pioneer AppRadio 3)
Old Apr 5, 2015 | 07:48 PM
rmc1148's Avatar
Glad you figured it out. Does your radio need a security code, make sure mutes not on.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
HolmaN
Aug 19, 2015 07:32 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
