Vibration at 88mph
Old Apr 22, 2015 | 11:37 AM
SamboTT@ByDesign's Avatar
How old are your tires? New enough to warranty? I have gotten good support in such a case from my Toyo re-seller once. Especially if you show how you have been trying to solve it. Or old enough to just replace?
Old Apr 22, 2015 | 04:03 PM
996ttPA's Avatar
996ttPA is a jewel in the rough996ttPA is a jewel in the rough996ttPA is a jewel in the rough996ttPA is a jewel in the rough
My buddy changed tires around August and I bought the car from him in end of September. didn't drive the car much but did notice a slight vibration at first. Thought it was just bad balancing from newly replacing tires. Stored the car for the winter. I've had them rebalanced and road force balanced a few times. Tires are bridgestones and probably have about 1500-2000 miles on them so still plenty of tread. Problem is I think they were bought so long ago that warranty wouldn't cover it.
Old Apr 22, 2015 | 08:10 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
try a spare set or wheel/tire or borrow a set?
Old Apr 23, 2015 | 03:37 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
do me a favor and lift the rear, so the tire is of the ground - put one hand at 9 oclock and another hand on 3 oclock and move left to right, put your hand on 12 oclock and 6 oclock and move it up and down, see if have any movement, maybe control arm/s/busings are busted/, should be no movement.
it could be several things, tires, rims, busted bushings, maybe trans is making vibrations or axles. could be busted shock/s
I'm sure alignment is fine, otherwise usually it happens around 60mph's
also best bet would be to borrow 2 rear wheels from a friend and test it. Tires could be bad, do to age, maybe at one point car was for several months.
Old Dec 30, 2023 | 08:18 AM
TheMotor1's Avatar
TheMotor1 is infamous around these parts
Not too revive an old thread, but I'm having a similar issue. 99 C2. Vibration over 70mph. I've swapped another set of 4 wheels and tires and the vibration stayed with the car, so i was able to eliminate wheels/tires all together as a cause. Any thoughts?
drug delivery
Oct 24, 2015 11:04 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
