Question: How much oil do you burn?
Old May 29, 2015 | 10:13 AM
  #46
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
jinjgn: are u a troll...or bot..
Anyways.
my theory: if u do lots of short trips, the engine will burn more oil, cause the engine parts dont reach the max expansion inside the engine. If the engine is hot it seals perfect. For example. If i ride 500 km on the autobahn, my engine does not need any oil at all. If i ride the same distance in like 20 single turns it does use oil. Makes sense for me. What do the experts say!
Old May 29, 2015 | 11:43 AM
  #47
rmc1148's Avatar
A bot that I reported.
Old May 29, 2015 | 03:50 PM
  #48
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Originally Posted by '02996ttx50
the is no porsche dealership i have ever been to, and their master techs will tell you, that they also never drain the turbos. up to others to figure out why that is, and why the litre or so of oil mixed with nearly 8 quarts of fresh oil is going to make any discernible difference whatsoever. i'd sure like a plausible explanation, and if that is just because the person changing it is ocd and/or **** retentive, yet oil expurgative LOL, then so be it!
but i DO inspect my filters lol
Mark,
The last time I drained the turbos it was like about 200ml in total maybe less. So there is only a very small amount and not really worth the hassle of accidentally stripping the plug head. I dont think I will be doing them any more.
Old May 29, 2015 | 03:58 PM
  #49
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
As a reference, my air cooled cars have 1 Long oil line running from the back to the front oil cooler, then another line from the front to the back. The oil in these lines and the front oil cooler DOES NOT get drained when I change the oil.
My SC has about 200,000+ miles and after these miles from rebuilt, I still have about the same compression.
Old May 29, 2015 | 05:40 PM
  #50
BLKMGK's Avatar
Drained my turbos, used a proper Allen socket on them and cleaned the crud off of the plugs before wrenching them. Got a decent amount out, cleaned the threads, a touch of anti-seize on the threads going back in. Don't want those plugs freezing if you'll ever want to remove a tank since there's a mounting bolt inside! Car took a solid 9quarts to fill, drained all 4 drains completely.
Old May 29, 2015 | 06:31 PM
  #51
'02996ttx50's Avatar
thank you for consistently sounding a voice of and with reason
Old May 29, 2015 | 09:00 PM
  #52
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
FWIW, "996 The Essential Companion" states draining the turbos and comparing the amount of oil drained from each side as part of the engine oil change proceedure. A variation is indicative of a turbo seal leaking.
I always drain mine as it adds less than a couple of minutes to the job and keeps the plugs free.
Old May 29, 2015 | 10:05 PM
  #53
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
+1.. and,
1500km on Castrol 5w50, still no usage, and LOTS of hard running
another 996tt I'm running on Castrol 5w50 also not consuming...both seem quieter than on Rotella, will be trying another car soon on 5w50...
Originally Posted by nick49
i always drain mine as it adds less than a couple of minutes to the job and keeps the plugs free.
Old May 30, 2015 | 04:30 AM
  #54
well no doubt the plugs are there for a reason! still think i'll stick with what works for me. and charlie doesn't drain turbo's lol
but hoping my experiences with castrol 5/50 mimic yours. it is as quiet as i have ever heard it at startup, this after one week even w decats. i think it's a tougher oil, like pirelli is a tougher tire lol
Old May 31, 2015 | 08:51 AM
  #55
BLKMGK's Avatar
Comparing oil drained side to side seems silly to me. Those tanks hold oil drained from the turbos and have it extracted by the oil pump. I'd expect the oil pump to be able to keep up pretty well and for the volume passed to be pretty small since turbo bearings don't need much oil. For there to be a significant variance it would have to be leaking a pretty decent amount of oil! I don't think that's a very good reason to drain it out of those reservoirs but I do think draining is worthwhile. (Shrug)
Old May 31, 2015 | 10:04 AM
  #56
rmc1148's Avatar
I would drain them just to keep them free if nothing else= have fought my share of stuck differential drain/fill plugs and not fun.
Old May 31, 2015 | 12:38 PM
  #57
i guess porsche dealerships have never read the essential 996 companion. just when you think they do everything by the book, they get lazy when they can, and no one will be the wiser for it since no one will ever know the turbos haven't been drained. unless of course the drain plug is seized from never having been turned lol. there IS that.
Old May 31, 2015 | 12:42 PM
  #58
rmc1148's Avatar
I doubt also it would cause any issues never botheringg as they hold such a small amount but doesn't hurt and they stay free. Just fought a battle with a drain plug on my Audi differential= no fun.
Old May 31, 2015 | 04:43 PM
  #59
BLKMGK's Avatar
I used a touch of anti-seize on mine just to help prevent that. Sprayed a ton of carb cleaner and cleaned it all real good before I even attempted to unscrew mine. I've got a ratchet with the proper size for the Allen as well. Mine unscrewed no problem which was nice. If nothing it allowed me to use a full 9quarts and not have a dribble left in the bottle. Castrol Edge 5w50 I think it was. I'll check to see if I've burned any this week.
Old May 31, 2015 | 05:30 PM
  #60
^ I've just driven hard since memorial day when i changed ( 8 qts since i didn't drain the...lol ) w the edge 5/50. it seems to like it.
gauge hasn't moved from one mark below top. i never topped off since i was checking for consumption short term. that's encouraging.
