Leak from Front Turn Signal? Coolant or....?
Old 07-12-2015, 10:24 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Orange is the De-icer. It works just as well as the regular but when you need it, melts the ice. No need to bother with blue.
Old 07-12-2015, 10:41 AM
rmc1148's Avatar
I've heard its hard on paint with the additives but that may be bull?
Old 07-20-2015, 08:09 PM
BlueDream996's Avatar
BlueDream996 is just really niceBlueDream996 is just really niceBlueDream996 is just really niceBlueDream996 is just really nice
Originally Posted by 32krazy!
give sean at silly rabbit a call. he can prolly make some with the new cnc machine he has
It's not that easy to make radiators!
Besides the point.. If you want to get new CSF rads, PM me with your email address, and I'll work out a great deal with a dealer of mine for you.
Old 07-21-2015, 02:20 AM
32krazy!'s Avatar
its not that hard for him! he has all the equipment needed and custom core manufacturer to build cores to his specs. its an alternative was my point.
Old 07-21-2015, 02:25 AM
'02996ttx50's Avatar
those cnc machines are near miraculous tech for us old(er) guys. but would a customized one off set have had the testing done that already marketed ones *should* have? i suppose you could always enter into the program someone else's proven specs ( duh ).
Old 07-21-2015, 08:02 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
whatever you do, do not taste/drink coolant, its bad for you...
btw, you can tell how coolant smells, rotten eggs, and its a little bit greasy- if you dont get any coolant smell, its probably washer fluid. just take the front bumper off and inspect, its hard to say, because water/coolant/oil can travel anywhere and find the way to drip somewhere....
Old 07-21-2015, 08:13 AM
rmc1148's Avatar
MadWhip always ads some humor 6spd desperately needs lol.
Old 07-21-2015, 09:06 AM
levinsje's Avatar
levinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to behold
I had the same windshield washer leak issue happen to me a while back.
I poured in some orange fluid in and it came right out the bottom at the same location near the driver side tire. It turned out to be a hose that came off near the bottom of the plastic washer tank. I took off the front tire and plastic wheelwell cover. Then it was an easy fix to plug the hose back in.
Old 07-21-2015, 01:51 PM
rmc1148's Avatar
On my a4 if you don't get the pump turned to just the right spot it will leak= tried new seal no difference..
cadman
10-04-2023 12:36 PM
audipwr1
09-25-2021 01:31 PM
Enemy
11-10-2015 08:01 AM
The_Ruski_Driver
10-25-2015 08:40 PM
Zero911
08-24-2015 06:51 PM
Quick Reply: Leak from Front Turn Signal? Coolant or....?
