Rear bumper removal. Am I missing something obvious
Old Nov 22, 2015 | 03:24 PM
996TTFTW's Avatar
996TTFTW is infamous around these parts
Hey guys. taking apart my car somewhat while its in storage.. Starting with the rear end as I'm going to plugs and upgrade boost hoses.
I've undid all the obvious screws including the lights, on the bottom, the top and the corners of the bumper, but it feels like it is being held on still at the middle.
Do I have to take off the bumperettes to remove the bumper?
Old Nov 22, 2015 | 03:38 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
yes bumperettes have to come off
4 screws at the top centre, 1 at each side leading edge of bumper into quarter panel, 2 each side at bottom leading edge near tire, 1 each side bottom near exhaust tips, bumperettes
careful with wiring when pulling bumper off, license plate lights and reverse sensors if equipped..
32krazy!'s Avatar
yes. theres a small piece under the bumperette. don't scratch it. pop it ur and inside theres a torn bolt that has to be removed. use a long extension
Old Nov 23, 2015 | 10:29 AM
996TTFTW's Avatar
Got it! Thanks guys!
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
yep. easy job. now you have to take off the intercoolers. and heat shields to replace sparks. also check on the coils maybe its good to replace them as well....they love to crack overtime.
btw, how did you lift the rear. I can see the jack-stand (center) is it resting on a trans ? hard to telll. i hope not.
Old Nov 23, 2015 | 12:44 PM
996TTFTW's Avatar
I'll likely do the coils at the same time.
I have it resting on two stands holding the subframe (I think it's called the subframe, I suck at part names lol). I jacked it up on each side point infront of the rear wheels with two separate jacks.
bunob
May 25, 2021 02:12 AM
dblcrwn
SoCal
Oct 18, 2015 09:20 PM
markj
Oct 18, 2015 08:35 AM
markj
Oct 6, 2015 07:25 PM
bonemechanic
Cayenne Turbo
Oct 6, 2015 08:15 AM
