Silver bullet build
Well just starting my big build here this weekend. Like usual I go from buying a car and saying I'm not going to do much....to go overboard.
This build is named after the stuff I'll be drinking most of the time while buidling it, good old coors silver bullets aka shop beer. This is kinda of a special car in my area. Being in North Dakota and northern Minnesota, a 911 turbo is not a common site. I bought my 01 gt2 clone out of California in august and I love the car. At the moment it had a codd stage 2 tune and was fun but not fast enough. Here is the current list so far. Was hoping to have it ready to go to tx2k but probably won't be done till april. Engine Proefi 112 wth flex fuel sensor K20/billet 20g turbos (new size turbine between a k16 and k24 I'm trying) 1300cc injectors running e85 and 91 Ipd 74mm plenum and tb 3.5 inch intercoolers (wise will probabaly go to a 4.5 at sometime) Custom Y pipe Custom fuel system, dual 450lph walbro staged with fuelab fpr Fender intakes 3 inch xpipe catless exhaust Torque solutions motor mounts Torque solutions trans mount bushings. Drive train Exedy triple carbon r clutch Wavetrac lsd Rwd Suspension H&r coilovers Gmg sway bar with HD links Solid subframe bushings Solid thrust arm bushings Poly inner lca and toe arm bushings Torque solutions dogbox arms Brakes Ss lines Rpf 600 fluid 350mm rotor with spaced stock calipers Pads (have not decided yet on compound) Wheels and tires Forester cf10 wheels 19x9 19x12 Re11 tire 255/35/19 and 325/30/19 So excited about the car and build. True dream come true. https://cimg1.ibsrv.net/gimg/www.6sp...f465eed7bf.jpg https://cimg6.ibsrv.net/gimg/www.6sp...84a569cce9.jpg https://cimg7.ibsrv.net/gimg/www.6sp...345eb6d1f2.jpg https://cimg1.ibsrv.net/gimg/www.6sp...4722f7f1be.jpg https://cimg2.ibsrv.net/gimg/www.6sp...f1aab666b5.jpg https://cimg5.ibsrv.net/gimg/www.6sp...269ea938d8.jpg https://cimg4.ibsrv.net/gimg/www.6sp...3aa5850dc3.jpg https://cimg7.ibsrv.net/gimg/www.6sp...5f57ca9a93.jpg |
Good luck with your project. Bringing all the way to TX2K16™ would be fun. Look me up if you make it down.
Who's going to tune it? |
Originally Posted by BlackHorseTurbo
(Post 4461742)
Who's going to tune it? Matt Sandbeck for Sandbeck race development (srd) is tuning it. He's a local guy and a friend. Best tuner I've ever worked with. Very talented and actually cares enough to spend extra time making tuned perfect in all areas. He does lots of aem setup but this is the first proefi so we will have a learning curve. |
Looks like a very cool build!
Will you be machining a stock K16 turbine housing to fit this new turbine wheel or a new housing all together? Good luck! Keep us updated. |
DO IT Freddy!! :D
Originally Posted by gophaster
(Post 4461964)
Will you be machining a stock K16 turbine housing to fit this new turbine wheel or a new housing all together? Good luck! Keep us updated. Only costs me 850 to build the turbos. If I upgrade again it will be to efr7163 but that would be after a motor build. |
Looks fun. Subscribing
Sweet, looking forward to your results!
Originally Posted by flewis763
(Post 4461993)
Machining out the k16 housings. Easy to do. I've been hundreds of turbos over the years, always like to try new stuff and make new designs.
looks awesome freddy. let me know when your ready. theres a lot of cool things that are waiting to go in the car!
Cool build, go bizon!
Originally Posted by 32krazy!
(Post 4462159)
looks awesome greedy. let me know when your ready. theres a lot of cool things that are waiting to go in the car!
Originally Posted by mdurbahn
(Post 4462203)
Very cool! Where are the compressor/turbine wheels from? Please post some detail pics when you do the turbos.
Originally Posted by stevemfr
(Post 4462737)
BTW i go have some billet k16 size wheels for sale if anyone needs them. they are what i was going to use until todd told be to just say screw it and go big. |
Here is the difference between the billet k16/k24 small wheels (47.5/66/70.7mm extended tip) and the k16/k24 billet 20g wheels (52.5/68/73.2mm extended tip)
https://cimg9.ibsrv.net/gimg/www.6sp...6343ebe51c.jpg https://cimg1.ibsrv.net/gimg/www.6sp...01cdd84f5f.jpg https://cimg5.ibsrv.net/gimg/www.6sp...6db91f2056.jpg |
