Driving light upgrade do I use same bulbs as fogs
Old Nov 28, 2003 | 03:33 PM
  #31
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Here is the bulb chart
Bi-Xenon low beam...............................D2S 35W
High Beam with Xenon...........................H11 55W
Fog Lights...........................................H 3 55W
Rear Fog Light......................................P 21 W
Reverse Light
Tail Light, Brake Light............................P 21/ 5 W
Raised Brake Light................................W 3 W
Turn Signal Light..................................PY 21 W
Parking Light Front "City Light"................H 6 W
Side Marker Light.................................WY 5 W
Door Guard/Kurb Light...........................W 5 W
License Plate Light................................C 5 W
Luggage, Engine, Interior Light................K 10 W
Reading Light.......................................6 W Xenon
Old Nov 29, 2003 | 08:47 AM
  #32
Poursha's Avatar
Poursha is infamous around these parts
Originally posted by EM 996 GTS
I dont have the pic,
but they are not blue at all... infact still a little yellowish.
I will take a pic right after my car is out from the show.
If you could take a pic with the lights on, and one with them off, that would be great.
Is your car one of the cars in the Topline booth? I didn't have a chance to go to the show this year, but Zim said he had a few Porsches in his booth.
Old Nov 29, 2003 | 11:59 AM
  #33
msindi's Avatar
Check my sig for pics...I think EM and I have the same bulbs but am not too sure...
Old Nov 29, 2003 | 01:26 PM
  #34
EM 996 GTS's Avatar
EM 996 GTS is infamous around these parts
sure, Ill take some pics when the show end.
yeah the turbo in his booth is mine... along with my friends cars
Old Nov 30, 2003 | 01:11 AM
  #35
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Reverse Light
Thanks a ton!! Now, I need to know which exact, generic or other brand makes fog and driving lights that are the same voltage and intensity and preferably match the xenons. Anyone know and can confirm which ones I need? Thanks
Lou
Old Nov 30, 2003 | 12:17 PM
  #36
LSM's Avatar
LSM
Senior Member
Originally posted by topdaytrader
you can find out more info at http://www.motionr.com
topdaytrader(TDT, from now on if that's ok )
thanks for above website it is very helpfull. Is there any problem if I upgrade my xenons to 6000k and then use the superwhite 6000k for my fogs and driving lights?? Will it emit too much heat and possibly melt the casing?
Lou
Old Nov 30, 2003 | 09:01 PM
  #37
topdaytrader's Avatar
topdaytrader is infamous around these parts
Thumbs up
6000k will look awesome on your car. It won't overheat or melt the casing.
Old Nov 30, 2003 | 09:17 PM
  #38
LSM's Avatar
LSM
Senior Member
Would I need new ballasts for the xenons or can I just substitute the 6000k bulb. I will then use the 6000k bulbs for both the driving lights and fogs. Hopefully it will match better than my current fogs. PIAA 55w=110w 4150k. BTW, what do Porsche xenons come in at, 4300K?
Lou
Old Nov 30, 2003 | 09:24 PM
  #39
You don't need a new ballast. Just need to replace the D2S bulbs. It'll definitely match better than PIAA. They still look too yellowish and not enough brightness.
Old Nov 30, 2003 | 09:36 PM
  #40
LSM's Avatar
LSM
Senior Member
Great, do you know what wattage I would get? The website doesn't offer different wattage options for the H3 or H7 bulbs. I heard that if the wattage is to high it will melt the casing or short out the entire light assembly. Thanks again for all your help. Also, just to clarify, I would order two of each 6000k bulbs:
D2S(xenon bulb)
H3 super white halogen fogs
H7 super white halogen driving lights
Would I need anything else?
Lou
Old Nov 30, 2003 | 10:00 PM
  #41
LSM's Avatar
LSM
Senior Member
D2S draws 35w and around 80w for halogen bulbs.
They won't overheat, melt or melt. I use them on all my cars w/o any problem.
You can see more comparison pics at http://www.dreamtrade.com/cgi-bin/ya...num=1067673711
Which set-up do you use on your Turbo, 5000k, 6000k? Do the fogs match? the driving lights? and which bulbs do you use?
Lou
Old Nov 30, 2003 | 10:03 PM
  #42
LSM's Avatar
LSM
Senior Member
How do I order?Is there a way to order on the phone,I always get a little nervous about disclosing personal info on the net, encrypted order form or not
Lou
Old Nov 30, 2003 | 11:14 PM
  #43
dbelleperc's Avatar
LSM, Just to let you know the 6000K bulbs will not be brighter than the stock bulbs 4100K. But if you want the blue effect you will get it.
Old Nov 30, 2003 | 11:16 PM
  #44
dbelleperc's Avatar
TDT, Who makes the 6000K xenon's? And if I remember correct from rennlist don't you own motionr.com?
Old Dec 1, 2003 | 12:41 AM
  #45
LSM's Avatar
LSM
Senior Member
How could they not be brighter, they have a much higher temperature output. They seem to be much brighter and much more blue. Please let me know your thoughts
Lou
