AFR rises after dropping to 14.7
Hi All,
I swapped in a silly rabbit fuel system with one walbro pump with -6 going all the way back to 1000cc injectors. Flashed the car with a 91oct base flash from Mitch @ Cobb. On a cold start the AFR is around 19.0 then once it warms up it drops to 14.7. After a min or so of idling the AFR starts creeping up and will get really high on bank 2. Any suggestions?
The point of the fuel system upgrade is to run e85 but starting with the 91 file.
Thanks in advance for any suggestions.
- David
- David
